Flathead question?
Discussion in 'The Hokey Ass Message Board' started by the duke, Oct 5, 2003.
  1. the duke
    the duke
    My friend has a flathead block that is in nice shape except that the lifter valleys are pitted. He was thinking that a brake hone would maybe fix it but he and I have no clue what the correct way or if there even is a way to fix this. Thanks for the help! [​IMG] The Duke
  2. Flat Ernie
    Flat Ernie
    Tech Editor
    I've seen them bored & sleeved with bronze & honed to fit, but it ain't cheap...having said that, if the block is crack free otherwise, might be a worthwhile investment...
  3. Digger_Dave
    Digger_Dave
    [ QUOTE ]
    [/ QUOTE ]
    I'll****ume you mean the "lifter BORES."
    If the pits are not too deep/big then a quick pass with a hone would probably clean them up.
    But don't get too carried away.
  4. Bruce Lancaster
    Bruce Lancaster
    If the pits are at all deep, you can't just remove them by heavy honing--that'll leave them oversize and you'll have slop and rapid wear, probably. I'd say give them a light pass with a hone, then see how much original surface is left (the shiny part) between the pits. If there's a good deal of surface left, and no concentrated area where the surface is all gone, you can probably run them. They are not pressure fed, and the whole valvetrain in a flathead is very lightly loaded compared to those silly modern engines. Boring them out and sleeving them would be an excellent fix, but would likely cost more than a block that didn't need fixing.
