flathead question
Discussion in 'The Hokey Ass Message Board' started by tudorfritz, Jan 3, 2010.
  1. I just bought a 1950 shoebox Ford. The car is all stock and is an older restoration. My question is, I would like to replace the stock carb and intake with a Edelbrock super dual intake and two Holley 2100 carbs which I have; is this to much carburetor for a stock motor?
  2. 49 Custom
    49 Custom
    Hey there tudor!
    2x2 works just fine. Keep in mind you will have to make a few other modifications (such as moving the generator) but it is otherwise a nice swap. If you have the stock distributor, the vacuum advance will not work properly if connected to the venturi port on a 2100 because the pressure drop is now split between the two carbs. So, while you're at it, you might want to swap the dizzy out as well to something with a centrifigal advance.
    -Stefan
  3. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    yea, it'll work fine
    Put a fenton intake with 2 strombergs, mallory dual point, edelbrock heads, and reds headers on a stock original 53 merc flathead.
    Runs real smooth, and the power increase was noticable
  4. hotrod-40
    hotrod-40
    It should work fine. Do a search in the tech threads to find out everything you need to do.
