Technical Flathead radiator hose pipe kits
Discussion in 'Traditional Hot Rods' started by tarheelrodr, Dec 20, 2023.
  1. tarheelrodr
    tarheelrodr
    I am curious about the flathead radiator hose pipe kits I see advertised as well as homemade rad pipes in general.
    Are these just for aesthetics or is there a functional or technical reason why they are used?
    Tow Truck Tom likes this.
  2. rusty rocket
    rusty rocket
    To me a nice bit of stainless steel bling looks good. I run them on my T modified and they actually hold the radiator from tipping back.
  3. krylon32
    krylon32
    from Nebraska
    I have used several of the stainless upper hose kits from Speedway over the years with no problems. Only thing I do to make sure they stay tight and don't leak is put a light coat of sealer around each pipe when I slip it into the hose for the last time.
  4. FritzFord
    FritzFord
    from Nashville
    As for function, if the pipe is close to the water neck on the head on pre-49 heads, it would help keep the thermostat from traveling up.
  5. daleeric
    daleeric
    from Omak
    I used the Speedway stainless steel and they turned out nice. IMG_2760.JPG IMG_2760.JPG
  6. ClarkH
    ClarkH
    I got a set because my Offy head center-outlets are 2" and the 8BA rad inlets are 1.25". The tubes are 1.75". It's really easy to reduce 2 to 1.75 and 1.75 to 1.25.
  7. Bandit Billy
    Bandit Billy
    I know those ribbed rubber "donkey ****s" are traditional but I prefer the look of the polished SS pipes. A little bling here and there is nice.
  8. cederholm
    cederholm
    Do you have a photo of the other side? Like to see how that pipe is nestled between the blower and the generator. ...and about all that polished aluminum - DAMN!!! :eek::cool:
    Bandit Billy likes this.
  9. Bandit Billy
    Bandit Billy
    This an ancient photo during construction. It has room using this offset Navarro gen bracket.
    ClarkH, Tow Truck Tom and cederholm like this.
  10. Eh-Bone
    Eh-Bone
    I like the S/S look also, the problem is the Speedway kits are not meant for p/u’s…anyone know where these can be had for 1950 F1 with the flatty?
    I called Mid Fifty’s but they only carry the stock steel ones.
    Tow Truck Tom and Bandit Billy like this.
  11. Bandit Billy
    Bandit Billy
    I don't use Speedway for much, I think mine came from Flathead Jack. You can purchase mandrel bent aluminum or SS on line in whatever lengths you want. I did that on my desoto hemi as radiator hoses are not exactly over the counter to fit my 40 ford radiator. I bought the pipes and made my own.
    Eh-Bone and Tow Truck Tom like this.
  12. Mo rust
    Mo rust
    I just use the chrome plated br*** sink traps that just cost $8 or $9 from Walmart.
    sdluck, sidevalve8ba, Packrat and 5 others like this.
  13. cederholm
    cederholm
    Thank you - what a beautiful motor that is.
  14. Bandit Billy
    Bandit Billy
    Thanks, and it not just for show, it is a good runner as well.
  15. sidevalve8ba
    sidevalve8ba
    I miss Flathead Jack........
    D type likes this.
  16. BJR
    BJR
    On a car I am working on at work we used curved rubber hose with a straight SS pipe. Worked great.
