Technical Flathead running hot and pinging
Discussion in 'The Hokey Ass Message Board' started by Buzoom, Aug 15, 2022.
  1. Buzoom
    Buzoom
    from Florida
    I have a 59 block in my 40 ford. Has 2000 miles on it. Running one Holley 2 barrel of a 3 deuce intake. Iffy heads. Electronic crab dissy retarded as far as it will go. Has been running great since the car was built. Engine temp was a constant 175°. Suddenly it developed running at 190-200 and starts to ping.
    Has anyone experienced the same symptoms? What was your solution?
  2. inthweedz
    inthweedz
    Sounds like it's running too lean, fuel supply, pump, carb jet blocked. manifold/carb base air leak???
  3. Buzoom
    Buzoom
    from Florida
    Thanks for your input. Running Elec. Pump. Elec. Vac. Pump for power breaks. Will check carb and fresh fuel.
  4. Last edited: Aug 15, 2022
    Jalopy Joker likes this.
  5. Bandit Billy
    Bandit Billy
    If the heads are iffy I'd replace them with some good ones. Pics of the intake would be nice.
  6. Lean fuel mixture would do that. If that checks out then check your timing. Retarded ignition results in heat. I think those are the two most likely culprits. Good luck
  7. Budget36
    Budget36
    Thinking typo, O and I are next to each other.
    Buzoom likes this.
  8. Flathead Dave
    Flathead Dave
    from So. Cal.
    Bandit Billy and ClayMart like this.
  9. Buzoom
    Buzoom
    from Florida
    You're right.
  10. Buzoom
    Buzoom
    from Florida
    Auto spell correct dosent know Offy
    Bandit Billy and Budget36 like this.
  11. Buzoom
    Buzoom
    from Florida
    Electronic distributor should not change. Has been running fine and is retarded as far as it goes. I believe more advance = more heat.
  12. Buzoom
    Buzoom
    from Florida
    Problem solved. I went to check the plugs to see if there was any sign of coolant getting into a cylinder. Aha!
    #8 plug wire was not connected at the plug. No Ping Temp at 175
    Kiwi 4d and Bandit Billy like this.
  13. Btw, the guy that came up with spell check passed away recently...his funnel will be tomato.
