Technical Flathead temp sensor
Discussion in 'Traditional Hot Rods' started by kennj, May 4, 2020.
  1. kennj
    kennj
    is there a aftermarket temp sensor part number for a 48 merc flathead 12 volt,
    Is there a way to check one of these?
  2. tubman
    tubman
    There are aftermarket sensors available, but from what I know about them they are not very good and don't last long. Before I get into it, what do you know about the "King-Seeley" gauge system? (It is a system used by Ford and works differently than most gauge systems.)
    The usual way to use original 6 volt Ford gauges on 12 volts is to install a voltage reducer on the power to the gauge.
    warbird1 likes this.
  3. kennj
    kennj
    Gauges are new and car is 12 volt, I grounded the sensor wire and the gauge went full up so I know the wiring and gauge are ok, I would like to know how to check the sensor
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    This may help.
  5. tubman
    tubman
    I will repeat : Do some research on the King-Seeley gauge system. If you don't understand the difference between it and the usual gauge systems, you will be forever confused.
    BTW, the senders are repairable; I have done it.
  6. stillrunners
    stillrunners
    from dallas
    I managed over 125 properties for CitiBank in the good old days....best tool I had was one of those laser temp gun sensors I could shoot at the HVAC vents to see what was coming out...and let the *****in person know.
    When I was having trouble with a temp gauge - I thought - on an old 318 Poly - never seemed to get hot - pulled the cap many a time with no boil over - but wasn't convinced. A buddy said shoot that thing - with a temp gun - did and that dang old Poly was not getting hot at all.....that old wagon was a beast I should have kept.
