Hot Rods Flathead throttle linkage or rod/cable set up
Discussion in 'The Hokey Ass Message Board' started by C0ra1l1, Apr 7, 2020.
  1. C0ra1l1
    C0ra1l1
    I'd appreciate if you would post pictures showing a functional and traditional looking throttle linkage or rod/cable set up for one carb. I took a pic as it is now - performs just well enough but I'm planning to make it work and look better. Screen Shot 2020-04-07 at 20.55.14.png
  2. Flathead Dave
    Flathead Dave
    from So. Cal.
    What is the flathead in? have you thought about the s**** throttle linkage?
    This is mine.
  3. GordonC
    GordonC
    Here you go. Old style s**** pedal mounted on inside of firewall and rod through the wall out to the carb. Simple and works well. Pictures are a little dark. 20200218_201831.jpg 20200218_201843.jpg
  4. WB69
    WB69
    from Kansas
    This is the setup on both of mine. Works great!
    Flathead Dave likes this.
  5. Flathead Dave
    Flathead Dave
    from So. Cal.
    ^^^Mine too. Easy to do and works the best.
  6. CobraJoe
    CobraJoe
    For duals, but I'm sure it would work fine for a single carb.
    Flathead Dave and olscrounger like this.
  7. olscrounger
    olscrounger
    ^^^ This works great. If using a carb with linkage on other side I move/weld an arm on that other side--done many.
    Not real fond of the cable throttle setup
    warbird1, Flathead Dave and CobraJoe like this.
  8. C0ra1l1
    C0ra1l1
    Thanks for your advice. I have a s**** pedal and will start planning a linkage to make the setup smooth and dependable.
