After searching, with no luck I'm hoping someone can tell me what pressure plate bolt pattern is needed for a TKO 600 for my 8BA Flathead. Also open to suggestions regarding flywheel as well. Thanks in advance... Posted using the Full Custom H.A.M.B. App!
All TKO 600's have the same 26 spline as a super T10 or M22 [ it is only the input shaft length that changes between the GM and Ford varieties ] So the Clutch plate needs to be 26 spline, and the diameter needs to match the pressure plate. The pressure plate needs the bolt pattern to your flywheel regardless of the gearbox. I use a 10" diameter clutch for road racing with a TKO 600 [and drive it onto the trailer] mated up to a 157 tooth flywheel. That would be overkill for a flattie Start with your flywheel, and get a clutch to suit
