flathead to 5 speed tech?
Discussion in 'The Hokey Ass Message Board' started by Tim, May 2, 2006.
  1. Tim
    Tim
    from KCMO
    hey guys,
    doing a search ive run across a few posts discusing products and results but im failing to find an actual tech article with some pix of doing it? im sure it cant be all that hard as its just adapters but as often as it comes up and for what a good conversion it is id think a tech article would be great to have around
    if ive missed it in my search can somebody link me?
    thanx
    tim
  2. What kinda trans are you planning on using? Tell us what your planas are?
    Rat
  3. Tim
    Tim
    from KCMO
    no solid plan right now but i was thinking 53 v8 block to s-10 5 speed.
    oh and for linkage concerns its a 53' customline curently having the 3 speed w/ overdrive
    but im mostly looking for the motor/trani info
  4. I used an adapter from flatattack to mate up to a Toyota 5 speed gearbox.
    Works real good, nice bit of kit.
  5. krylon32
    krylon32
    from Nebraska
    Try Cornhusker Rod & Custom, they have what you need.
  6. 50flathead
    50flathead
    from Iowa, USA
    Dwight Bond in Gibbon NE is another good source.
  7. I used a cast iron 8BA bellhousing and had it modded slightly to accept a Toyota stell case 5 speed.
    Works like a champ....have pix somewhere but need to dig em up !!
    Rat
  8. CDNflatlander
    CDNflatlander
    I found a 'rodder' that put a set of 'prints' together for guy's like us, this is a full set of plans (read - tech) that is easy to follow.
    Try e-mail to greenhough@telusplanet.net , his name is George.
    CDNflattlander.
  9. curtiswyant
    curtiswyant
  10. Tim
    Tim
    from KCMO
    cool ill give that a shot. THIS is the kinda of thing im looking for. a pictorial how to. not so much a " i used this kit, or got it from this guy" kind of post. because thats all i found when iwas looking for some actual photo do***ented tech onthe subject.
    thanx
    tim
