flathead to c-4 trans
Discussion in 'The Hokey Ass Message Board' started by hotrod35, Aug 17, 2008.
  1. hotrod35
    hotrod35
    from IL
    A friend of mine is building a roadster for his grandson. He is using a 53 Ford flatty and wants to use a C-4 auto. Any good adapters around? I've heard horror stories about one well known flathead dealer. Not sure if they are true though.
    Thanks in advance
  2. Saxon
    Saxon
    from MN
    Speedway has them.
  3. Flat Ernie
    Flat Ernie
    Tech Editor
    Wil-cap
    Flat-O-Matic
    Speedway
  4. jaysberman
    jaysberman
    Flat-O is great. Gene Benson is easy to talk to and will help with any questons.. I am running two of his.
  5. Capitan Insano
    Capitan Insano
    Flat-o is the best C4 adapter
  6. langy
    langy
    I've got an adaptor for my Y block from Gene and can only say what a nice guy to deal with, I've also had a Flattie adaptor and wouldn't go anywhere else.
  7. dv8
    dv8
    I used the Speedway kit...bolted right together...just had to drill a couple of holes out a little bigger on the block.
  8. tjm73
    tjm73
    Of you guys running C4's on Flatties, how do the flat motors run with a C4 behind them?
    Are they peppy? Sluggish?
    A Flathead seems like a perfect match to an auto as they are all torque all the time.
  9. jaysberman
    jaysberman
    faltheads run well behing the c4. I am running 3.0 rears to keep the flathead from turning to high at arround 70mph. One car has a gear vendors over drive that work well. Both cars are have lots of power and leave a light at a good clip.
  10. dv8
    dv8
    Mine moves out real strong....My motor is pretty hot though.
  11. Flatman
    Flatman
    I used the Speedway kit. The starter nose they sent didn't work, but I used a standard Ford truck starter instead. You have to be sure you have the correct size bell housing for the flywheel they provide.
    Flatman
  12. 2002p51
    2002p51
    I can echo that. I also have 3.0 gears and C4/flathead combination, and with 29" tires that works out to about 65 mph @ 2,000 rpm. It won't do long smokey burnouts with that gear/tire but it pulls nice and strong from a light.
