Customs flathead to c4 auto trans
Discussion in 'The Hokey Ass Message Board' started by Charles Rogers, Jul 27, 2019.
  1. Charles Rogers
    Charles Rogers
    For those of you who have done this conversion. Do you think it was worth it?
    After driving mine in heavy traffic today I am thinking about doing it
  2. cartman4gc
    cartman4gc
    I've done that. worked GREAT, got the stuff from Gene Benson at Flat-o-matic
  3. 40FORDPU
    40FORDPU
    Second that..works great, also used Gene at Flat-o-matic.
  4. Flathead Dave
    Flathead Dave
    from So. Cal.
    Yes I did and I think it is worth doing. I have to have an automatic because I can't clutch any longer. I used the Speeadway Kit. $400.
    There are others and are more expensive so it depends on which kit that you want to use.
  5. paleot
    paleot
    from louisiana
    I had the speedway kit, Worked ok flatomatic looks much better. I would choose an automatic with overdrive I think someone said a FMX would work. My C4 always felt like it needed another gear.
  6. krylon32
    krylon32
    from Nebraska
    I've done them with both the Flatomatic and Speedway kit. Both worked good. I like the appearance of the Flato kit although on an 8 BA it needs the intermediate bell housing but is a direct bolt up to the 59 block. I've also done a few customer ch***is with the Speedway 8BA/AOD conversion and my customers report good performance. I have a friend with one of my ch***is under his deuce 2 door with a fuel injected FH and C4 and it really performs great.
  7. roseville carl
    roseville carl
    x2 on Gene at Flat-O-Matic, a great kit
  8. Charles Rogers
    Charles Rogers
    Thanks I will look into the Flat-O-Matic kit.
    Chuck
  9. 4ford
    4ford
    from Eagan. Mn
    flat-O-Matic is the way to go Gene will talk you thru any issues
  10. uncle buck
    uncle buck
    Just to clarify this comment, the FMX is not a overdrive
  11. Atwater Mike
    Atwater Mike
    Ha, ha... Argued this point with a 'know-it-all' in this valley when I got here.
    I had done a Fordamatic conversion, in '78.
    The tallest range you get with FMX is 1:1.
    There are 'experts' around, so watch out... BTW, this 'expert' has moved to the Phoenix area of Arizona.
    (watch out, Squirrel):eek:
  12. The AOD is based off the FMX design... I believe there's even a few shared parts.
  13. Flat Roy
    Flat Roy
    X3 on the Flat-O-Matic. I've been run mine for ten years behind a supercharged flathead. Love it
  14. derbydad276
    derbydad276
    AOD ... use a Lokar TPS cable kit
    and make sure you adjust it correctly
