Flathead to chevy smallblock kit
Discussion in 'Parts For Sale' started by coupeguy2001, Apr 26, 2024.
  1. coupeguy2001
    coupeguy2001
    from Phoenix
    City: Phoenix
    State: Arizona
    Price: $1500
    I have front mount, bell housing adapter, flywheel, 3 finger clutch, trans adapter, dust shield, bolts.
    This kit allows you to install a small block chevy engine in any ford flathead powered car.
    You get to use your trans and driveline without changing anything but the engine, radiator, exhaust, air filter, and generator.
    I can add a set of new block hugger headers for $100 more.
    You can use your original ignition coil if you keep your car 6 volt, but then you need to get a 6 volt chevy starter, and swap starter end bell.
    Easy engine swap, but i wouldn’t go over 250 horsepower because of the trans and rear end keywsy keys limitations.
    I have a running 327 with a comp cam 268H available for $800.
