Technical flathead to t5 speedometer
Discussion in 'The Hokey Ass Message Board' started by johnale, Nov 30, 2014.
  1. johnale
    johnale
    from Melbourne
    Hey guys,
    I have recently had an S10 NWC T5 installed in my 40 ford with stock rearend and i'm running 6.00 - 16 ford script rear tyres.
    I can't get to get my speedo to read properly, what is the best thing to do to get at least a semi accurate speedo.
    Any advice would be great.
    Cheers
    John
  2. krylon32
    krylon32
    from Nebraska
    On the T5 transmissions I sell the builder always asks me to get the tire size and rear end ratio so he can install the correct speedo gear set in the trans. Never had any complaints so far. I once went to my Chevy parts man who had a chart with the right gear combinations for various tire size and rear end ratios. That was several years ago when manual speedo drives were more common.
  3. johnale
    johnale
    from Melbourne
    I thought that may have been the case, knew I should have done that before the install, I've found a calculator on line and based on tyre size and rear end I need an 18tooth driven gear for what I'm running
  4. bri0057
    bri0057
    Instead of taking the trans apart now to change out the speedo gear, they sell inline adapters that you can change the ratio's with. Search for Stewart Warner speedometer reducers on ebay. You can pick them up at swap meets for $5.
  5. 69dz302z28
    69dz302z28
    from ks
    First you need the tire diameter Divide this by 20168. This will equal revolutions per mile. Next see what drive gear you have. Multiply drive gear teeth , gear ratio, and revs per mile. Take this total and divide by 1001. This will equal the drive. Gear tooth count you will need
