Setting up my flathead on an engine test stand. Radiator has just one top inlet and the flattie requires two. Can the motor's two top hoses be Y connected into the rad's one inlet without causing overheating or whatever? Engine will be limited to idle with and a few occasional bursts. Thanks.
How big are the inlet/outlet pipes on the radiator? Those two water pumps move a lot of water. It's not hard to modify the rad with extra inlet/outlet pipes, a rad shop would probably do it for you fairly cheap. Flatman
