Flathead trans question
Discussion in 'The Hokey Ass Message Board' started by freakytiki55, Mar 3, 2006.
  1. freakytiki55
    freakytiki55
    Hi all. I introduced myself a while back and have been lurking around to get the feel of the place a bit. I tried the 'search' ****on, but couldn't find what I was after. Maybe you all can help.
    I have a later version flathead and want to install it in my '27 T Coupe. Someone told me that certain Jeep transmissions from the 70s will bolt right up. Is this true, and if so, which ones?
    Thanks in advance for any help.
  2. 50flathead
    50flathead
    from Iowa, USA
    I have never heard of a direct bolt on except for one of Henry's own. The T-5 is what gets all the press today. Check over at the Fordbarn for more answers.
  3. freakytiki55
    freakytiki55
    Thanks...will do
  4. 302GMC
    302GMC
    from Idaho
    The Jeep thing you heard about is for the shifter - the 3 speed Jeep lid fits on a '49 up Ford T-86 if you do a bit of clearance work.
    302
  5. jetmek
    jetmek
    i think the one you want is a 4 spd....3plus an o/d gear. i dont know the model but fellow hamber NOBODYS HERO has one thats for sale. mike is in N.J. i think frank oddo's flathead book also mentions it.
  6. Flat Ernie
    Flat Ernie
    Tech Editor
    Hadn't heard that, but makes some sense.
    The Jeep conversion I know about is for a T-176/177 top shifter onto a Ford T&C Toploader ****** with a bit of clearancing work on the top of the case. David Kee transmissions is repopping entire Toploaders & the Jeep shifters now too - otherwise, good luck on eBay as they don't come up often & when they do, they go for silly prices - prolly have better luck in the local truck junkyard.
    Might be talking about the late-model Ford 3+OD as found in Trucks, Granadas, & Monarchs in the mid-late '70s - again, these are Toploader copies, so the Jeep T-6-177 shifter tower option probably works with them as well.
    Check the search function for T5 info. Loads of it here & recently posted again too...
