Technical Flathead V6....
Discussion in 'Traditional Hot Rods' started by Cutlassboy68, Jan 20, 2012.
  1. Cutlassboy68
    Cutlassboy68
    from Boone, Nc
    Ok so its been a long week at work with thing after thing breaking, I.E. an M-22, broke my press, and my finger. I went and got a customers '53 ford truck with an 8BA cause he couldnt get it to start, been sitting for a little over a year, Oil pan was leaking, so we replaced it, and cleaned out the pan, cleaned out the fuel tank (nasty varnish gas), cleaned out the fuel pump, rebuilt the carb (it was full of trash and the float was stuck), had to take the distributor out cause he had messed with it and was no longer on TDC for #1, points were fried, new cap, new ****on, new starter relay, and all that good stuff. Anyways, I got it started... Sounds HORRIBLE!!!
    Got my compression tester... No compression on cylinder 3 and 6... I think the valves are stuck, filled the cylinders with Marvel Mystery Oil and letting it soak... Anything else i can do short of taking heads off?
  2. gas pumper
    gas pumper
    Gotta get the oil on the valve stems. stuck valves are usually the stems rusted in the guides.
  3. flatjack
    flatjack
    Filling the cylinders with oil won't do anything for the valves. Pull the plugs. You will be able to see one of the valves and maybe a corner of the other one. See if the one that is visible is hanging up. If so, carefully tap it down, crank it over, keep tapping it down till it hopefully frees up. Otherwise , pull the head. Also, could pull the intake to see if any valves are sticking.
  4. HOTRODPRIMER
    HOTRODPRIMER
    Never heard of a Flathead V6,,how about a inline 6?
  5. Mike Miller
    Mike Miller
    But you get extra points for using a compression tester to troubleshoot the problem.:D
  6. hotroddon
    hotroddon
    Dang I was excited, thought maybe there was a cool little V6 Flatty I didn't know about :mad:
  7. Ebbsspeed
    Ebbsspeed
    I submit that he's referring to a flathead V8 with two dead cylinders, hence the V6 reference.
  8. Thats what I think he Means, here I thought I was going
    to see something realy Special that I never Heard of
    oh well
    just my 3.5 cents
  9. I have Heard of a V4 and worked on one but Never
    a Flathead V6
    lol
  10. the V4 was Not a Flathead its overhead Valve
    Lancia Car
  11. retroridesbyrich
    retroridesbyrich
    from Central NC
    Saw a couple of V4 Chevrolets in midgets. (Cut down SBC)
  12. Brian C
    Brian C
    Kinda like this one.......
  13. I suspect he was refering to a wisconsin flathead v4?
    zzford and seb fontana like this.
  14. Ole don
    Ole don
    On a flathead Ford V8, leave the heads on and remove the intake. That is far easier, and you can see which valves are stuck and deal with them. The gasket may be able to be saved, costs less if you need to buy one, you dont need to drain the coolant, and there are half as many bolts.
    55styleliner likes this.
  15. hotroddon
    hotroddon
    Ford made the cutest little V4's as well - and SAAB used them in some of their cars, like the Sonnet
  16. flathead okie
    flathead okie
    Yeah but thy're not flatheads
  17. Ebbsspeed
    Ebbsspeed
    If you can see the exhaust valves by taking off the intake, you've got a relatively serious problem........
  18. revkev6
    revkev6
    from ma
    huh. you must have discovered some top secret engineering defect with every single flathead v8 ever made lol
  19. Wow. I'm making popcorn!
  20. RidgeRunner
    RidgeRunner
    from Western MA
    Gotta admit that the heading grabbed my attention!
    Ed
  21. RidgeRunner
    RidgeRunner
    from Western MA
    + 1 on the above.
    To verify it's a valve before starting that you might try putting air into a cyl in question at TDC through a plug hole adapter and listening to the intake and exhaust ends for leaks. Air into the pan could indicate cracked or holed pistons. Bubbling coolant could indicate cracks into the water jackets or a bad head gasket.
    Ed
  22. Ebbsspeed
    Ebbsspeed
    Jeez, what the hell was I thinking? Didn't even consider you can see the stems in the lifter valley, was just thinking about looking down the intake ports. Old man brain fart, I guess.
    55styleliner and seb fontana like this.
  23. Thats what Happens when you get Old
    Live Learn and Die a Fool
  24. Cutlassboy68
    Cutlassboy68
    from Boone, Nc
    Ok... Sorry for the misleading headline, just thought it would get attention... So can i pull the intake off instead? Its much easier to get an intake gasket than head gaskets.
  25. F&J
    F&J
    Speaking of those.... they were used by snowplow trucks to run the sand spreaders on the back.
    And during sitting all summer, the valves would be stuck open. The shop guys just bent up a stiff screwdriver to get through the plug holes. Almost always worked.
  26. Cutlassboy68
    Cutlassboy68
    from Boone, Nc
    So i pulled the intake off, Intake on #3 was stuck, made a tool that freed it up beautifully... Piston #6 was a different story... it was closed and bent, the keeper was shattered. Drilled and tapped the valve, threaded it to 1/4 20, put on my slide hammer and removed the whole valve ***embly. Had a spare sitting around. I took out the lifter to check it, was scared up, put a new one in, new valve ***embly, everything clearenced and ready for new gaskets and be back together... Much easier fix than i was expecting...
    Thanks for the help guys
  27. mtflat
    mtflat
    Those 3 exhaust ports will get you every time! : >
  28. 28dreyer
    28dreyer
    from Minnesota
    That was a German engine originally and was used in some models of their cars like a Taunus I believe and Industrial engines worldwide and was the basis of the V6 used in the Capri.
  29. Cutlassboy68
    Cutlassboy68
    from Boone, Nc
    Didnt think it was a v6... It was a V8 with 2 dead cylinders... but both were on the inner cylinders. Cylinders 3 and 6.
    Does any one want pics? Including tool i made?
  30. MutinyInc
    MutinyInc
    Digging up a old post here, but hoping someone may know what this is I believe it to be a flat head v6 but never seen anything like it, there’s 3 plugs and 3 injectors and the exhaust ports are labelled 1 2 and 3, does any one know anything about these.
