Hot Rods Flathead V8 Head Gasket Recomendations
Discussion in 'The Hokey Ass Message Board' started by hotrodbob, Jan 17, 2017.
  1. hotrodbob
    hotrodbob
  2. rd martin
    rd martin
    from indiana
    im interested in this also, does edelbrock recommend anything?
  3. hotrodbob
    hotrodbob
    Was just told by a V8 Ford club guy that Edelbrock recommends only copper gaskets. Just didn't say why. A friend is on the Edelbrock tech line, I'll call him and see what he says.
  4. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    image.jpeg After putting on your Edelbrock heads,be sure and visit your local boat shop and purchase a "sacrificial anode". You have a cast iron block,aluminum heads,and probably a br*** radiator. Having these dissimilar metals will cause your Edelbrock heads to develop "soft spots or mushiness" over a period of time.The reason for the anode is so these uglies or nasties in the water supply system(caused from the dissimilar metals) will "attack" the sacrificial anode and leave the aluminum unharmed.
    Kan Kustom, Texas Webb and hotrodbob like this.
  5. I think that only works when the parts are in salt water.
  6. hotrodbob
    hotrodbob
    Spoke with Edelbrock and they no longer recommend ONLY copper gaskets. The gaskets they sell are a composite like a Felpro. They also say not to use any coating on the gaskets. They say either gasket is fine. I used an anode on my coupe with limited success. Still ate my Edmonds head and then the aluminum water neck when I switched to a V8. I have just changed to Evans water-less coolant on the coupe and hope this works. Will try some of the Lucas product on my wife's car and distilled water.
  7. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Make sure you coat the gaskets with "Copper Coat" and do about 3-4 re torques.
  8. flatheadpete
    flatheadpete
    from Burton, MI
    I used copper gaskets with no sealer on them. Head studs are recommended and a few re-torque sessions wouldn't hurt a bit.
  9. hotrodbob
    hotrodbob
    Edelbrock Tech guy says not to use anything on the gaskets. I have new head studs to use and will re-torque a few times.. Thanks
  10. I used new edelbrocks with composite gaskets. No copper seal spray or Any of that. The new edelbrock heads are CNC made. So you know they will be flat and straight. Just make sure your deck it also true and flat. I used arp studs. I put the studs in with arp thread sealer. Then I put anti seize around the stud from the deck to bottom of threads on the stud. Make sure you don't get any anti seize on the threads. Then I use arp thread oil and torque them baby's down. Re torque 3 times after each run of the engine. You won't have a problem. The anti seize will come into play later on down the road if you ever need to take the heads off. You will need longer head studs for the edelbrock heads.
    hotrodbob likes this.
  11. flatjack
    flatjack
    Either composite or copper will work just fine. No sealer on the gaskets.
  12. 42merc
    42merc
    I'm also a fan of composite gaskets & NO sealer.
  13. wandi harry
    wandi harry
  14. hotrodbob
    hotrodbob
    Edelbrock says no sealer
  15. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    I didn't know you got married Bob, Congrats is in Order.
    Oh, BTW use Cyclone next build ;)....
    We'll talk soon,
    Kevin
  16. hotrodbob
    hotrodbob
    THANKS! Yup, got married on the starting line at Irwindale Speedway, July 2 during the "Night Of Destruction". 50 hot rods, 200 friends and family as well as 4000 of our newest friends.. It was great and still is.
  17. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    I wish Sharon and I would've known, we'd of helped celebrate as well. We should get to for a dinner soon.
    Congrats to Peg and you, wishing you the best.
    Your pal,
    Kevin & Sharon.
  18. hotrodbob
    hotrodbob
  19. tubman
    tubman
    Congratulations, folks! Now, back to gaskets. I used to use sealer on FH head gaskets, but I don't anymore. I found that a properly prepared ***embly doesn't need it, and all it does is make things tougher down the road.
  20. jimmy six
    jimmy six
    On water. My sons race car is not allowed use anything but water. With last yrs rebuild we ran only distilled water and tearing down the engine over the winter we found ZERO evidence of rust with only the intake and water pump being aluminum. It is a closed system with 30# cap and recovery. Distilled water works...
