Flathead V8 info???
Discussion in 'Questions & Suggestions' started by Reverendcolin, Nov 2, 2003.
  1. Reverendcolin
    Reverendcolin
    Want to build a flattie. It's been years since I've screw with these and when I did we just grabbed a decent running engine and put crap on it. Alum. heads could be got for around $10. a set the same for a 2 carb manifold with carbs and linkage.
    Anyway. What should I look for in finding a "good" motor? I've got a chance to pick up a 53 ford with a clean looking motor (looks like someone may have rebuilt it some time ago. Turns over. What years should I look for and what other things should I look for. What are they going for now.
  2. sedan_dad
    sedan_dad
  3. Reverendcolin
    Reverendcolin
    Thanks I posted there too.
  4. Jim Marlett
    Jim Marlett
    Any flathead without a crack or with a crack that is fixable is a good motor. Some people don't like '52 and '53 models because they usually don't have hardened valve seats which means they tended to crack more. I say if it has lasted until now, it doesn't matter. If you want seats, you can have them put in, but I wouldn't bother unless there is a compelling reason to do so.
    Any flathead you get your hands on is a "pig in a poke" until you check it for cracks.
  5. Reverendcolin
    Reverendcolin
    Thanks for the info.
    I knew I'd heard something about the later motors but couldn't remember what it was.
    Guy wants $400 for the car(53 4-door). Wouldn't be bad if it was a standard but it's a ford-o-matic. Body is crap. I know I can get it for $200. That may be a bit much too. Maybe a trade would do the trick
