flathead v860
Discussion in 'The Hokey Ass Message Board' started by vonstripers, Jan 24, 2010.
  1. vonstripers
    vonstripers
    from france
    someone can tells me more about this engine,it's looks like a v8 60 ford ,a friend of mine tells me that it comes from little ford truck from 1948.....!
    here's the pix
    thanks
  2. 40 was the last year
    tk
  3. Stefan T
    Stefan T
    from Sweden
    There is 17 bolts head so it is a V8 60
    They were used on Ford (Simca) Vedette on the late 50's
  4. Stefan T
    Stefan T
    from Sweden
    You are from France so it are from a france made Ford
  5. Heo
    Heo
    Yes absolutly 50s vedette
    maby they used the engine in some
    frech truck but transmission is
    also Vedette probably the 84 hp
    version can be 66 hp
    Looked on the pics some more
    its the older version with integrated
    bellhousing came in the vedette
    that look like a small 49-50 mercury
    66 hp i think
  6. I had two (Ford) Vedette engines and on on the left next to the intake manfold there is the engineno. and both started with * F 472 ......*
  7. ventilo
    ventilo
    looking at the transmission and the pull rods I' guess it's not taken from an open drive car
    so I'd say pre-war Matford (F472) rather than post-war Vedette
    the F472 was continued under the SAF Ford brand post 1945 for some time and there was a commercial off this chassis
    Vedette had four bolt (not three bolt) Solex carbs as far as I know
  8. Heo
    Heo
    I dont think matford had that distributor
    but not sure
    iwe seen both 3 and 4 bolt vedette carbs
  9. Deuce Daddy Don
    Deuce Daddy Don
    First ones came out as optional in 1937 Ford cars, the little V860, or the larger std. V8 85 (horsepower).-------Don
  10. Crestliner
    Crestliner
    Front mount dist., exhaust manifolds, look like my Vedette engine. Can't see bottom of the block. For sure its not American.
    Went back and looked, mine has freeze plug in each head. Had a 4 speed columm shift open drive. It was in a 59 Vedeette.
  11. Heo
    Heo
    Yes deuce daddy i know the 37-40 werry well
    but this engine is a French Ford.
    Later Simca bougt the French Ford factory they made the
    60 hp based engine i france to about 1960.
    Then they continued the production in south
    america, they even made them with hemi heads(120 hp)
    as Chrysler...esplanada i think they was caled
    around 66-67 i think it was
