flathead ???? valve angles? the same?
Discussion in 'The Hokey Ass Message Board' started by hiboy32, Sep 13, 2008.
  1. hiboy32
    hiboy32
    from Omaha, NE
    does anyone know the valve angle on a flathead?? and is the valve angle the same on the left and right sides?
  2. lowsquire
    lowsquire
    from Austin, TX
    I believe its different, If you gave this post a less mysterious ***le, maybe Bruce Lancaster or someone else with more Knowledge may chime in with a definitive answer.
  3. hiboy32
    hiboy32
    from Omaha, NE
    I think that is a great idea. Lets see if Bruce can answer this.
  4. lowsquire
    lowsquire
    from Austin, TX
    the hamb will come through soon.
    I think I recall that the crank and cam are slightly offset related to the centreline of the block, to absorb or offset combustion side thrust loads!??? This is my wonky memory trying to recall something read a while ago..
    One thing i DO know is the valve height in relation to the deck is slightly different side to side, and machining to try to 'even it up' is a no-no.
  5. The V8 Flathead Ford the crankshaft centerline is offset 0.265" to the right. As for valve angle I believe it is 45 deg.
  6. Andy
    Andy
    The angles are different side to side and they changed post war. The pre war engines had the valves laid down a little more and are closer to the bores. Might have moved them due to cracking??
  7. hiboy32
    hiboy32
    from Omaha, NE
    I tried a search, I also remember something a while back about the valves being different.
    I didnt realize that crank is also off set.
  8. loudpedal
    loudpedal
    from SLC Utah
    This help? I'm trying to find a picture for you...
  9. loudpedal
    loudpedal
    from SLC Utah
    The dimensions for the 59 series engines would not be the same as the valve angles were changed prior to near '45.
  10. hiboy32
    hiboy32
    from Omaha, NE
    thanks Kris, that is what I was looking for. I was hoping for some more info on the 59 series also.
  11. BigVinDaddyMac
    BigVinDaddyMac
    Hmmph....interesting, didn't know that. Good question and good answer.
  12. alchemy
    alchemy
    The valves are not different side-to-side.
    Early, with a mushroom tip, are different than late, with a regular grooved tip.
  13. hiboy32
    hiboy32
    from Omaha, NE
    Ok, the valves are the same, what about the angle of the valve in the block?
  14. Bruce Lancaster
    Bruce Lancaster
    Sides differ, and '32--maybe 44 and '46-53 differ...I do not have actual numbers here, I think they haver around 100 degrees separation (valves are canted toward cylinder) ...easiest source is the cross section drawing collection in various '38--48 Service Bulletins, on the back of each engine's dyno chart.
    Blown 49 sell posters of a late cross section!
