Have a small flathead that need water pump pulley. This is the pulley used on water pump that is mounted to a 1 piece casting (a timing cover) The pump does not have its own outlet as the outlet is on the engine. It uses a 5/8" belt and does not have a "dome" top. Any suggestion? Have tried several well known sources, but no luck. Thanks
Sounds like a 60 horse flathead. Do you know what year it came from? I think the first couple years (37-39?) had different water pumps than the last ones (1940).
