Technical Flathead water pump rebuild
Discussion in 'The Hokey Ass Message Board' started by PSMITH-40, Apr 23, 2021.
  1. PSMITH-40
    PSMITH-40
    from Warsaw, MO
    So I'm in the process of rebuilding a set of water pumps for my flathead, but I'm unsure of something. The rebuild kits I bought from Dennis Carpenter have an impeller with a groove for an internal clip, but didn't come with one. The pumps I'm rebuilding didn't have the clip or a groove in the impellers. The pumps I pulled off of my motor have the clip. My question is do I reuse the clips or re***emble the pumps without a clip? 20210421_162726.jpeg 20210421_162857.jpeg 20210421_162844.jpeg 20210421_162908.jpeg
    Sent from my SM-G960U using The H.A.M.B. mobile app
    OzMerc39 likes this.
  2. alchemy
    alchemy
    I've rebuilt about a dozen 40 water pumps and I've never seen that clip in any of the pumps or kits. I've used new kits and old stock rebuild kits.
    I'd think you would want the pressure to always press against the seal (such as it is - not really a seal) and a clip might restrict that pressure. Maybe the clip is just to keep it all together while being ***embled, but after the pulley is pressed on the group is tight and the clip is not holding the spring any more?
    PSMITH-40 and alanp561 like this.
  3. PSMITH-40
    PSMITH-40
    from Warsaw, MO
    Thank you for the help. I've been trying to figure it out for a few days now. I didn't want to do it wrong and end up having to pull them apart again and start over. I really appreciate it.
  4. 19Fordy
    19Fordy
    OzMerc39 and PSMITH-40 like this.
  5. krylon32
    krylon32
    from Nebraska
    MART Just recently had a short video showing him rebuilding a pump.
  6. PSMITH-40
    PSMITH-40
    from Warsaw, MO
    I actually had watched Mart's video and that's why I decided to try and rebuild a set. Here's the pumps I'm rebuilding after a little bead blasting and some primer. 20210420_123401.jpeg
  7. Fortunateson
    Fortunateson
    This will be good.
  8. I am about to attempt the same with my 8BA water pumps... I have the Carpenter rebuild kit.
    I did watch Mart's video and another one on YouTube.
    I kinda feel prepared however it seems that I need a press ??
    PSMITH-40 likes this.
  9. 19Fordy
    19Fordy
    Yes, you need a press. Those pump pulleys break easily.
  10. alchemy
    alchemy
    I've done plenty of 59A pump rebuilds with just a large vise and sockets. But a press is much easier. I just have a Horrible Freight 20 ton H press, but it works fine and didn't cost much. I should have bought one years before I did.
    I've never done a rebuild on an 8BA pump. The shaft/bearing ***embly might be even touchier than the 59A bushing, so a press might be required.
  11. 19Fordy
    19Fordy
    Peruse this helpful info. about water pump rebuilding.
    Another possibility: I had my 8RT water pumps rebuilt by "SKIP" Haney on Fordbarn for about $200. This includes new and improved spiral bladed impellors for improved flow and gaskets. Pictures show rebuilt pumps.
    It's worth the money. Skip is in Florida and has been rebuilding pumps for years.
    https://www.google.com/search?q=reb...33i22i29i30.6200j1j4&sourceid=chrome&ie=UTF-8
