flathead water pumps from speedway
Discussion in 'The Hokey Ass Message Board' started by kantgetnun, Apr 27, 2007.
  1. kantgetnun
    kantgetnun
    are they really that good? do they keep the motor that much cooler than stock? anyone check temps before and after?
  2. Flat Ernie
    Flat Ernie
    Tech Editor
    I know they have the later impeller design, but their benefit is really in the bearings & seals. They use roller bearings like the truck pumps & ceramic seals - fewer leaks. Don't know that they cool that much better, but if you're buying new pumps, you won't find the old-tech pumps much cheaper...
  3. AV8 Dave
    AV8 Dave
    To add to Ernie's observations, they're the only pumps you can use if you are using early pumps on a late (8BA) block as they have sealed bearings and the 8BA blocks have no provisions for oil supply to the bushing-fitted stock early pumps. Regards, Dave
  4. Casey
    Casey
    they are worth every cent ! I have had a pair on my coupe , for 15 years with no leaks .
