Flathead wont restart??
Discussion in 'The Hokey Ass Message Board' started by tuki, Jun 14, 2011.
  1. tuki
    tuki
    thanks..yeah we just did that.a guy told us about that.so im gona have to check the floats and fuel level next week..thanks for all the help.i also want to check and make sure im getting enough spark out of my switch.it was acting weird..thanks
  2. tuki
    tuki
    well figured it out..i lowered the fuel pressure to 2 1/2,the float/fuellevel is lowerd..well still did the same thing..come to find out all along it was my ign switch!..it wasnt making full contact inside i guess.when it was turned to on it still didnt light up the test light..turn it a lil further to on and bam lights up.so i knew the switch was wore out..i turn it hard to the right and it fires up every time..
    thanks for all the imput and suggestions
  3. George/Maine
    George/Maine
    With the 2 terminal solinode it doesn,t go thur switch to start, just would stop when key was let go.Good you got it going.
  4. plym_46
    plym_46
    from central NY
    Had a tech at the dealership I worked at scratching his head couldn't find an intermitant ignition problem, truck wouldn't start, truck would cut off going down the road, truck would die after starting from a light would die in mid turn or going over bumps. It was and older truck that had nearly 200 K miles on it that was in otherwise good condition and when it ran, ran well.
    Tech was scratching his head as he could not duplicate the situation. I just happened to be in the cashiers office when the guy picked up the truck. He was unhappy that there was no fix but he was happy there was no charge because there was no fix.
    Cashier gave him his paper work with the key stapled to it, he removed the key, then pulled a key ring/s out of his pocket with about 40 or more keys, a couple flashlights can openers and a leather man dangling, and clips the truck key to it.
    I followed him out, and asked him if that weight was always hanging from the ign lock, he said since he bought the truck. I said just for the sake of argument, pull the key off the ring and drive it around for a while then come back and let us know how its been behaving. He came back about two weeks later and reported that in that time the truck had only cut out on him once, when he went over a rough 3 track rail crossing. I had also discussed with the tech. So he called me over when the guy came back, and noted his problem was almost gone. He decided to get a new ign lock installed, and he also decided to put his truck and house keys on one ring and his work and "other Keys and stuff" on a seperate one.
    Guess ing locks only have a certain tolerance for 5 lbs of stuff hanging, swinging and bouncing off them.
