Technical Flathead won't start!
Discussion in 'Traditional Hot Rods' started by LukeCrawford, Dec 26, 2015.
  1. LukeCrawford
    LukeCrawford
    Hey everyone, so before I begin I'd like to say that the 8ba I rebuilt was running before this problem. It has a merc crank, and Navarro heads, it was running very poorly at high rpm so I decided to bring it home for a valve set and new malory distributer over winter. Now the problem is that the truck is cranking and for the life of me I just can't get it to go. It has fuel, spark and iv triple checked the timing and even took the intake manifold back off thinking I had messed up the valve set.. anyways what else could make this thing not start?! Thanks
  2. LukeCrawford
    LukeCrawford
    The truck also has 2x2 intake with speedway 97 carbs, 6 volt system
  3. 19Fordy
    19Fordy
    Post your question on Fordbarn. Those guys know their flathead stuff.
    Also, post photos if you can.
    LukeCrawford likes this.
  4. ClayMart
    ClayMart
    Have you pulled the new Mallory and tried it with your previous ignition system which had apparently worked before? Have you done a compression test or at least a cranking vacuum test?
  5. LukeCrawford
    LukeCrawford
    Yes I have just put the old distributer back on. Still the same thing. I don't know what the heck happened. It should atleast start without vacuum shouldn't it
  6. wearymicrobe
    wearymicrobe
    from San Diego
    Throw the old distributor back on, pull the plugs and crank it a bit as well to see if you have fuel and pressure. Make sure you keep a rag handy. Check timing mark confirmed with TDC check.
    Sure you don't have the distributor 180 out.
  7. Hot Rod 50
    Hot Rod 50
    I don't know flattys but all motors are the same in this respect. One time I had a motor that looked right but absolutely would not fire. I figured out that the power I had going to the coil went dead while it was cranking. Recently I learned that some solenoids have a byp*** to run up to the coil so you get a full 12 volts to fire up with if you have a ceramic insulator in line. Something to look at. Is it popping and trying to fire or just nothing?
  8. LukeCrawford
    LukeCrawford
    Lots of fuel, and timing mark has been lined up but I can't get it running to actually set it
  9. Does it pop like it wants to fire or no spark at all?
  10. OzyRodder
    OzyRodder
    Check you have power at coil. If you do, crank it and check if you get a spark from a plug wire. If you do then electrically it should run.
    I've just been through some issues with my flathead. Try following the process in my thread and see what you come up with. (Dual Stromberg 97 tuning)
  11. ClayMart
    ClayMart
    No cranking vacuum means there's no way to pull a combination of fuel and air into the cylinder where it can be compressed into a combustible mixture. You only need to be able to pull an inch or two of cranking vacuum to do this. Valve seating or valve timing problems can cause a drop in vacuum, as can slow cranking speeds. If you're checking cranking vacuum, disconnect and plug any vacuum lines to the intake and carb. And back out the idle speed screw and make sure the throttle plates are fully closed.
    http://what-when-how.com/automobile/engine-vacuum-test-automobile/
  12. LukeCrawford
    LukeCrawford
    It sounds like it's going to go but won't. . It backfired through one of the carbs
  13. Dirty Dug
    Dirty Dug
    It sounds like your distributor is 180 degrees out.
    lodaddyo likes this.
  14. ^that.
  15. LukeCrawford
    LukeCrawford
    It's definetly not thanks tho
  16. Dirty Dug
    Dirty Dug
    It's about the only reason it would be backfiring through the carburetor.
  17. stimpy
    stimpy
    timing gear set not set right ( off a tooth or 2 )
  18. LukeCrawford
    LukeCrawford
    Sorry Doug it doesn't seem to be doing that now. It is cranking over with spark and fuel in the lines
  19. LukeCrawford
    LukeCrawford
    Really? Because I haven't touched anything and it was running before
  20. clem
    clem
    Chances are it will be 'something' that YOU have touched. Go through all those things first.
    Get someone else to check timing - sometimes it the little things that you miss.
    New plugs do amazing things sometimes....
  21. stimpy
    stimpy
    if it gets sloppy or worn it can jump teeth ( specially if its fibre or had a hard backfire or worn and reused if it was aluminum ) . a couple of teeth can rack up degrees at the distributor quickly and the valve timing will be way off too . and you said you had high rpm problems too ( sign of retarded timing )
  22. captaintaytay
    captaintaytay
    Lots of fuel? 1 1/2 to 2 1/2 lbs., about where it should be.
  23. LukeCrawford
    LukeCrawford
    IL check tomorrow
  24. yruhot
    yruhot
    Plugs wet? maybe super flooded for some reason?
  25. LukeCrawford
    LukeCrawford
    Nope black soot kinda they are new I'm using NGK B-6L
  26. 97
    97
    Sure sounds like a timing problem, but every tune/fire up should start with a compression test. You say it was running bad before you changed things. DID you compression test it then? It may well have a stripped timing gear or a blown head gasket.
    Check compression now(on every cylinder. Make sure #1 is coming up to compresion just as the rotor is turning to the corresponding ( #1) terminal in the distributor cap.( turn by hand with your thumb over plug hole to feel compression building , it's easier if done while all plugs are out). If the rotor is pointing anywhere else but #1, take the distributor out and reset it.
  27. captaintaytay
    captaintaytay
    How did your flathead run before this?
    Black sooty plugs sounds also like a rich condition.
  28. clem
    clem
    Black soot and too much fuel sounds like same thing.... Sitting over winter - may be carb problem ? Stuck needle valve etc..?.
    yruhot likes this.
  29. LukeCrawford
    LukeCrawford
    I have done this I'm sure it's in the right spot. Going to check fuel pressure and I have no idea how these carbs work so I'm going to trailer it back down to the shop tomorrow
  30. LukeCrawford
    LukeCrawford
    Yeah.. it is probably because I flooded it trying to get it to run.. you may be on track with carb problems though.. going to check tomorrow
