Hot Rods flathead
Discussion in 'The Hokey Ass Message Board' started by bangngears, May 19, 2024.
  1. bangngears
    bangngears
    from ofallon mo
    Trying to get a 40 ford flathead to fire. Cranks but no fire. Most of the time i am told most likely the condenser. Could also be coil or points, i am trying to see what you all think from past experiences. Car has sat for quite some time but surprised me when it cranked with the stater ****on and also noticed all the gauges moved when i flipped the ignition switch on. Thoughts please on most likely culprit
  2. manyolcars
    manyolcars
    corrosion on the points is the most likely culprit, followed by a bad condenser. coils rarely go bad but a swap with a good one is a quick test. Always clean all wiring connections, and grounds
  3. ClayMart
    ClayMart
    Center of the Galaxie likes this.
  4. jaracer
    jaracer
    Do you have a voltmeter? You can connect it to the distributor side of the coil and bump the engine over a few times. At some point you should have battery voltage at the distributor side when the points are open. When you bump the engine, the voltage should go to zero, or close, when the points close. If it always stays near battery voltage, the points are either corroded or not moving. If it always stays near zero, either the points are stuck closed or the primary wire is shorted to ground.
  5. RodStRace
    RodStRace
    Trying to fix an issue by sorting by most likely is a flat rate way to get it fixed quickly and make money. I'd suggest that awakening a vintage car is not flat rate, it's carefully inspecting all components of a sub system and confirming everything. While you are under the hood with the ignition on trying to get spark, you could have a corroded connection under the dash overheating.
    That said points, poor connections and then condenser would be the quick route.
    Tow Truck Tom likes this.
  6. alchemy
    alchemy
    Popping the side caps off a 40 distributor is sometimes hard when it’s in the car. Might be easier to take the plug conduits and wires off with the distributor and lay them on the bench.
    Or, pop take the coil off and maybe can gingerly get a rod inside to tap them out of the distributor housing.
    Either way, it’s much simpler to give the points a gentle filing and check their gap when it’s sitting on a workbench. Can also check the tips of the rotor and cap terminals. Make sure the advance is still working and the vacuum brake has a leather pad on it still.
  7. bangngears
    bangngears
    from ofallon mo
    Thanks guys. its been at least 50 years since i worked on flatheads. The only one i had was a 47 ford when i was 19. *81 now so i tend to forget stuff. Got 6 volts at the coil, so im going to do what JA racer said to try.
    Packrat likes this.
  8. wheeldog57
    wheeldog57
    Points I would say.
  9. bangngears
    bangngears
    from ofallon mo
    Pulled the distributer, cleaned points, ordered a condenser from Old Ford store in Springfield Ohio. Those guys are awesome. Never fail me.
  10. Bearing Burner
    Bearing Burner
    from W. MA
    Did you put some oil in each cylinder so you will have some compression? Pull the plugs add a little oil
    in each cylinder crank it over several time to get oil on the walls and rings working. Replace plugs add some gas and a shot of starting fluid and give it a try.
  11. bangngears
    bangngears
    from ofallon mo
    yup, all the above, with marvel and trans fluid. Turns nice with no hard spots or hangups. So when i get the condenser it should light off.
