Hot Rods Flatheads, love em or leave em?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Nov 21, 2016.
  1. Texas Webb
    Texas Webb
    Can't have too many flattys,I only have 4:D.
  2. stanlow69
    stanlow69
    My dad has one in his 51 Vicky with the stock drive line, also has the overdrive. It will run 65 mile an hour all day. 30 years ago it had an overheating problem, punched louvers in the hood--problem solved. 15 years ago, it started to smoke a little. If the motor showed any evidence of being not good, it would be history. Tore it down and rebuilt it. He wanted to put a 302 in it badly, The block was good, so it stayed. He runs a 3 duce manifold, only one carb is hooked up. Very, very few people notice that.
  3. car doctor
    car doctor
    Put a 52 merc flathead in my 32 when I was building it. Everybody thought I was crazy. Finished the coupe this past spring and put over 5800 miles on it this summer. Totaly trouble free and it ran perfect. I love the way it sounds and runs. I put an s-10 5 speed behind it, only way to go. Everywhere I take it everyone likes the looks of the flathead. 2016-06-10 05.55.43.jpg
  4. clunker
    clunker
    from Boston MA
    Exactly. Like one starving doberman pinscher saying to another "Listen, I know that's a raw steak he's dangling in front of us, but really, ignore it. Just pretend it's not there, woof, woof...."
  5. manyolcars
    manyolcars
    crestlinerskirts.jpg I ran a flathead for years and have hated them with a p***ion for 49 years. Recently my Crestliner has begun blowing steam out the tailpipe and I am sure its cracked between the bore and valve seat. The traditional solution is a SBC but I have not decided yet since I have 2 deuces, aluminum heads and the modern distributor for it.
    Baumi and DylanHill1931 like this.
  6. If I intended to drive coast to coast I would not try to pull too much horsepower beyond what Henry intended for it. Given that they should not have any problems.
    Charlie Stephens
    LOU WELLS likes this.
  7. Flathead Dave
    Flathead Dave
    from So. Cal.
  8. 49clubcoupe
    49clubcoupe
    from idaho
    I have four of them (three 8BA and one merc) on stands lined up in my shop right now. A few years ago I needed a standard bore 350 SBC block for my daily driver, I played hell trying to find one, just because I needed one. After that I vowed to hoard all the buildable motors that were offered to me for free or nearly free. The flathead guys in Oregon told me they will give $500 ea for usable cores.
  9. patmanta
    patmanta
    from Woburn, MA
    If it was ****oned up (plugs, carb) and running recently, there's a good chance it'll still run. I've had old guys tell me to throw flatty's like that on an old tire and start them ;)
    Out my way, a "runner" like that would run you about a grand (running).
  10. dumprat
    dumprat
    from b.c.
    I love flatheads! Just not those worthless Ford ones........
  11. Bader2
    Bader2
    [​IMG]Grab em! Ive got 18 of em around here,if they turn over,theyll run! Some better than others!
    LOU WELLS and patmanta like this.
  12. The only problem you can have with a flathead that you can't have with a valve in head is that you can't "drop" a valve. :D
    its just a motor, albeit a little under powered, but it is still just a motor. if it is in decent shape there is no reason not to drive it any place you would like to drive it. If it is wore slap out, and ill maintained it will also leave you just like any other motor.
    alanp561, rtsidejohnny and LOU WELLS like this.
  13. RRichFox
    RRichFox
    In 49 Merc went with the 4 inch crank. I think your ***le page answers your question. Flatheads. Love them or leave them for someone who does.
  14. bct
    bct
    building a car with a flathead at the moment but keeping an eye out for the sbc adapter kits and a nice early version of the overhead.
  15. Speed Gems
    Speed Gems
    Anytime you can get that stuff for free TAKE IT!
  16. alchemy
    alchemy
    The Drag-N-Fly needs a new bullet! Flathead!
    Roothawg likes this.
  17. Shamus
    Shamus
    from NC
    '52 8CM, .030 over, Isky cam, Edelbrock heads, 97s on an Edelbrock intake. Mallory electronic distributor, B-W T5 w/hydraulic clutch, 3.70 9", 65 MPH at 1800 RPM!!! What's not to love?? IMG_6153.JPG
  18. Fourdy
    Fourdy
  19. gearheadbill
    gearheadbill
    I can say that cuz I have 2 flathead powered cars, an over-built 276 8BA and a whole pile of other Mercury xtra engines. If memory serves me, I even gave you one. GET OUT IN THE GARAGE.
    falcongeorge and ClarkH like this.
  20. The weakest link on a flathead is the stock ignition. The cams are gear driven, less amount of moving parts in the valvetrain, overall simple. Mine has been running 10 years with one "breakdown"...the hot wire came off of the ballast resistor, put it back on and continued on. my way
    anothercarguy likes this.
  21. Gman0046
    Gman0046
    I've had two flatheads over the years and wasn't happy over the power they produced. I'll leave em.
    Gary
  22. Atwater Mike
    Atwater Mike
    I've had flatheads since 1955. Built some 'ultimates', (2, a 304" and a 316") and a couple of 296" ("3/8 X 3/8") then a few 5/16" X 1/4s. (274") Some 'stockers', but always with mild cam and aluminum timing gear.
    In 1962, I swore the 274" was my last, when I pulled it out of my '46 Coupe for my Reath Hemi!
    Then I built one more, in 1980. (nice 3/8" by 3/8", to go in my '27 Hiboy.
    Now, I have ONE MORE! Best bud Larry gave me a '48 59A block, factory relief, NICE .040 over, recent rebuild. DELTA grind (Winfield SU-1A) cam, two 94s, 59 AB heads. Mild, dependable.
    I have 4 more, too...'stored'. Just in case.
    Flathead fever? Recurring, methinks.
    falcongeorge likes this.
  23. Abomb
    Abomb
    If I had the space, I'd grab them for trading stock. I had a flathead powered car once...everything the HAMB says to do to build a reliable one was done...they're not for me. I'm far too much of a cheapskate to overpay for less than average performance... That doesn't mean that other people won't pay good money for them though...so, Free flatties=free money...
  24. falcongeorge
    falcongeorge
    from BC
    Roothawg, my guess is from your other posts, you aren't really a flatty guy, and neither am I. How does the thought of spending $5000+ on a motor that gets its *** handed to it by your neighbours SUV sound, exciting? Thought not...
    If you do take 'em, take 'em all. You will be lucky if one of the four isn't cracked all to hell.
    Abomb likes this.
  25. falcongeorge
    falcongeorge
    from BC
    I'd take 'em...And trade 'em to some fool with a 331 Chrysler that wants to be more "trad".:) Good trading stock, like others have said.
  26. bct
    bct
    Hot rod hero in an s10 pu.
    Bader2 likes this.
  27. Ron Brown
    Ron Brown
    You can leave the damn things.........right on my doorstep, thank you.
  28. daleeric
    daleeric
    from Omak
    20150912_163124_001.jpg Take them Root! Put the best one in your 36 pickup. Not fast, but fun.
    Ron Brown likes this.
  29. el Roach
    el Roach
    I have a little space in Washington state for them if you need storage :D !
    I have a 52 Merc flathead in my 34 5-window coupe, stock except for 2-94's, headers, and truck water pumps.
    It's a blast! Bolted it up to a t-5 and can cruise down the road 75.
    BTW flatheads like straight pipes!!!
  30. 1-SHOT
    1-SHOT
    from Denton
    IMG_1575.JPG I put a MSD box on mine and it's been trouble free for close to 15 years no problems and it will keep up with freeway traffic.
