Technical Flatheads with alloy flywheels
Discussion in 'Traditional Hot Rods' started by 61klassic, Oct 8, 2020.
  1. 61klassic
    61klassic
    from Kent UK
    Just though I would list my recent experience with an ally flywheel weighing 12lbs behind an 8ba, edelbrock heads, 2x2 intake fitted in a model a roadster at 1900lbs.
    all I can say is that it’s spot on!
    Yes I have the ideal car at 1900lbs, with 4.1 rear gears and a t5 trans.
    I can pull away in second with no throttle!
    It picks up quicker and no ill effects on engine braking.
    I’m sure if you have a 3 speed and/or heavier car it could be worse.
    But if not I say go for it!!
  2. 8flat
    8flat
    Sounds cool but I read they don't last long because the surface galls really bad? I.e. good for racing but not for street and stop-n-go traffic?
  3. Bandit Billy
    Bandit Billy
    I actually run one on my blown 8BA, runs great, revs fast, no negative reviews.
    kidcampbell71, KiWinUS, C69A and 2 others like this.
  4. 8flat
    8flat
    Does it have a steel insert so the clutch isn't using AL as the friction surface?
  5. Beanscoot
    Beanscoot
    Or bronze.
    Desoto291Hemi likes this.
  6. 61klassic
    61klassic
    from Kent UK
    Yep it has a steel insert.
    KiWinUS likes this.
  7. 37_Ford
    37_Ford
    from Illinois
    Run a 14 lb aluminum with steel insert on my 29 roadster. No issues in 20,000 miles. Blown 276 59ab, t5 with 2.95 first gear, 4.11 Traclok rear end.
    61klassic likes this.
  8. Automotive Stud
    Automotive Stud
    I'm running a 239 with an Isky 88 cam, high rise dual carbs, headers, aluminum heads, and a steel insert aluminum flywheel. It makes for a really snappy motor in my roadster with 4:11's. Not sure I'd use it in a fat fendered car with a flathead.
    I had reservations about using an aluminum flywheel with a 331 Cadillac in my '40, I was worried about losing torque. Boy was I wrong, no issue there either.
