Technical Flathed Head gasket problem? preference whats best?
Discussion in 'Traditional Hot Rods' started by Mr.Musico, Nov 12, 2013.
  1. Mr.Musico
    Mr.Musico
    from SoCal
    Had a 39 engine that may have been gone through 20 years ago, and it sat, and sat. I bought it painted it up, put carbs and intake and fired it yesterday.
    http://www.youtube.com/watch?v=X5eJW8BI6Zg
    It ran good, but i had water coming from the center of the head p***/side (and out the center exhaust port). I re torqed the heads in stages, cold and hot and still had the issue. I am hopeing its a bad head gasket not a cracked block. I am going to pull the heads off and hopeing the problem will be evident.
    Any prefernce for head gaskets? Materal type, copper vs newer style etc..? Thanks
  2. pinkynoegg
    pinkynoegg
    your video is set to private. I hear the copper gaskets dont work well with aluminum heads so I stayed away from them. otherwise its all preference really
  3. Mr.Musico
    Mr.Musico
    from SoCal
    ok, changed the video setting- ive heard the same regarding copper
  4. V4F
    V4F
    from middle ca.
    not much video to try to help .
  5. Jalopy Joker
    Jalopy Joker
    I was just at a old timers shop that has been into flatheads since the 50's - he says copper is the best - used them on street and at Bonneville
  6. Gene Boul
    Gene Boul
    Use a modern high performance composite gasket...maybe Best. Solid copper is the worst choice without "O" rings in the head or block. Copper composition would be OK but why spend the money for no gain. I'm ***uming this is not a racing flattie...
  7. Rich Wright
    Rich Wright
    I like composition gasket better tan copper and right now"Best" seems to be pretty highly regarded.
  8. Forgotten Ford
    Forgotten Ford
    Hi folks... just simple question, once I need decide which gasket I will purchase..
    I want purchase COMPOSITE gaskets for my 35Ford Engine, but the option that MAC site show to me is:
    Head Gasket - Steel Clad - Ford Flathead V8 85 HP 21 Stud ... $19.95 ea
    Head Gaskets - Graph***e - 85 HP - 21 Stud ...$33.80 ea
    Which one i should both?
    I will be happy to receive any suggestion of different gasket types or sellers!
    regardsRod
