Flattie RPM Redline?
Discussion in 'The Hokey Ass Message Board' started by Mike51Merc, May 12, 2010.
  1. Mike51Merc
    Mike51Merc
    What's a relatively safe RPM limit for a 49-53 Merc Flathead?
  2. holeshot
    holeshot
    from Waxahachie
    MIKE...the redline for all flatheads is, peddel to the metal and where ever it top's out is it...POP.
  3. ardyboy
    ardyboy
    we used to twist those little sidevalve junior dragsters to 9,000---that was pedal to the metal for 1/8 mile
  4. zzford
    zzford
    I wouldn't twist anything with only three main bearings much faster than idle!
  5. CAL
    CAL
    from Neosho Mo.
    Wow, really? And all this time I thought I needed my tach.....so, "tops out" doesn't equal "big bang"?
  6. promachine
    promachine
    from chico ca.
    Most if the ones I have run on the dyno top out around 4500. But.... I have heard from some old timers that if you want to make more power you gotta twist them.
  7. BillM
    BillM
  8. CAL
    CAL
    from Neosho Mo.
    So his Flathead "tops out" at 8,000, WOW. At 8,000 rpm I bet he used the full meaning to the word "launch". We don't call it redline anymore, the more technical term is "top out".
  9. CJ Steak
    CJ Steak
    from Texas
    I'd like to see him run 10 grand with a flatty.
  10. Yea me too.
    A flatty won't spin fast enough to grenade itself if it is mostly solid.
    10 K, yea right. There are guys running blown and on nitro on the salt that can't get 8 outa one. The first liar just doesn't stand a chance.
    Maybe an Ardun headed flatty but then again that isn't a flatty is it.
  11. hotroddon
    hotroddon
    The boys that built Flatfire, the world's fastest Flat Head (streamliner, 301+ out the back door) they reckoned that 6500 was about max for a tricked out (and their's made 700HP) Flat Head. And with **** Landy, Bruce Crower and Jim Middlebrook behind the engineering, I'll take their word for it.
    10,000? someone is pulling you leg!
    As for the OP's question, for a mild stocker, figure 5,000 is going to be more than you need and all that it can take.
