flatty belts
Discussion in 'The Hokey Ass Message Board' started by t/acoupe, Feb 20, 2007.
  1. t/acoupe
    t/acoupe
    from norfolk
    alright, maybe dumb, but how do i tension the water pump belts on my stock 50 flathead? just want to find out if there's a correct way before i go screwing something up.
    thanks,
    billy
  2. Dirty Dug
    Dirty Dug
    Loosen bolts, tighten belt. Leave a half inch if play. You are done now drive it like you stole it....end of story
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    I usually tighten to about 2 inches of play with stock pumps without the bearings. Too tight and your pumps will be leaking in no time.
    Bearing pumps are usually 1 inch play
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    The Ford Manual recommends 1/2" defection with "normal" thumb pressure taken between the water pump and the generator (first belt to adjust) then between the fan and the water pump (second belt to adjust.
  5. t/acoupe
    t/acoupe
    from norfolk
    there is no adjustment in the fan-crank-water pump belt, not that i see.
  6. Flat Ernie
    Flat Ernie
    Tech Editor
    The fan moves up & down. Loosen the big nut, move it up or down, tighten the nut.
