Hot Rods FLATTY WON'T START!
Discussion in 'The Hokey Ass Message Board' started by fordy6, Dec 30, 2022.
  1. fordy6
    fordy6
    Can't get flatty to start. Tried everything...Getting spark and fuel. I did notice some ac***ulation of fuel on intake manifold. Test metered all wires and Mallory electric ignition good spark and spark on all plugs.
    '46 59 A-B
    I thought maybe the float was stuck and removed top half of carb, looked fine. First attempt it turned over and ran for 10 seconds then stalled.
    Thanks, Mike
  2. ActionYobbo
    ActionYobbo
    Timing? Is the distributor locked down?
    Vacuum leak?
  3. v8flat44
    v8flat44
    Post on The Ford Barn too.....I'm thinking timing. Not a 59 a guy tho. 8BA i know more about.
  4. Mr48chev
    I'm probably not a whole lot of help but here is the page with the tune up specs out of my 1946 Motor manual. IMG_7422 (2).JPG
    Still for any engine to run you need a mixture of fuel and air, compression and igniton = spark all at the correct time.
  5. wheeldog57
    wheeldog57
    It ran and then it stopped. Good spark and fuel. It sounds like you are very close, these are finicky engines. @Pete told me earlier this year "sometimes it's a lot of little things" that keep them running good. Keep at it, small adjustments, and you'll get it
  6. fordy6
    fordy6
    I have a Mallory electronic ignition and have spark...
  7. fordy6
    fordy6
    No vacuum leak, distributor locked....I chased it to a poor engine ground..Started right up!
  8. fordy6
    fordy6
    thanks, chased it to a poor engine ground, started right up!
    '28phonebooth likes this.
  9. fordy6
    fordy6
    Thanks for post, I chased it to a poor engine ground....Started right up! Funny how electrons must have a complete circuit to work.
  10. fordy6
    fordy6
    Thx for the post....When I took the battery out to charge it I must have pulled on the engine ground, you know the braided copper ground wire? Anyway, I chased it to a no engine ground. bought a new ground wire and she started right up! Happy motoring!
    wheeldog57 likes this.
  11. fordy6
    fordy6
    Thx for the post, I chased it to a poor ground wire. replaced it and she started right up!
  12. fordy6
    fordy6
    Thx for the post, I chased the problem to a poor engine ground...Replaced it and she started right up!
    wheeldog57 and warbird1 like this.
