Technical Fleetline frame problem
Discussion in 'The Hokey Ass Message Board' started by 1950fleetline, Jun 1, 2018.
  1. 1950fleetline
    1950fleetline
    Looking for some advice.
    Discovered that a body mount bracket on my frame broke loose leaving a hole in the frame. It doesn't seem to be rusted out, or at least I hope it isn't!! I'm hoping this could welded, Anyone else ever had a similar situation like this? IMG_6950.JPG IMG_6948.JPG IMG_6946.JPG IMG_6947.JPG
  2. BJR
    BJR
    Clean it up with a grinder and beat it back into position, weld it back together. Done.
    Bandit Billy and 1950fleetline like this.
  3. 1950fleetline
    1950fleetline
    Thanks for the reply.
    I was thinking the same.
    Always like to get advice from others with more experience with cl***ic cars then myself. Appreciate it[emoji106]
  4. inthweedz
    inthweedz
    Yeah, agree weld it back on, just bolt it on first (where it bolts) so to get the surface angle correct, then it won't be under tension, causing it to break off again.
  5. rusty1
    rusty1
    yeah, those were just spot welded at the factory,...just weld it back on but be careful, those frames are thin...
  6. 1946caddy
    1946caddy
    from washington
    I would;d cut a patch that is about 1/2" larger the the whole on each side and place it over the whole and mark and cut out the old area and weld in the new metal. Then weld the bracket to the new metal.
