Flex Fan safety question
Discussion in 'The Hokey Ass Message Board' started by The Shocker, Jan 18, 2008.
  1. The Shocker
    The Shocker
    My old flex fan started pinging at idle ,so i inspected it to find that it had three cracked blades on it ,kinda scared me cuz i spin it to over 6000 often .I bought a new one today that i hope is better and safer .It has a sticker on it that reads high rpm flex fan 8000 rpm.Is this a bunch of hipe or is it better than the others ?I noticed the rivets , the ,body ,and the blades are alot thicker than the old one.I dont want to hurt anyone or myself if i can get a better one somewhere .It costs me $45.00 bucks if that counts for anything...
  2. Truckedup
    Truckedup
    8000 fan rpm,which may be faster or slower than the engine depending on the water pump and crank pulley sizes.I use one of those newer flex fans with the paddle type blades.Bought it a few years ago,said 8000 rpm max.
  3. HemiRambler
    HemiRambler
    Flex fans can make a mess of a hood real quick - one solution is to remove the hood. There may be other solutions as well.
  4. phat rat
    phat rat
    The best and safest use of a flex fan is use it as a wall hanger
    Spooky, Deuces, racer-x and 2 others like this.
  5. fatabone
    fatabone
    I just don't like flex fans. Speedway sells steel ones for $25 in different sizes.
  6. 8flat
    8flat
    My fancy flex fan let loose at less than 6000RPM, the blades had more fun than a tornado in a trailer park. It cut the rad hoses, fuel line, tranny fluid lines, vacuum lines, plug wires, fan shroud.....and tore a big hole in my radiator. It made a sickening sound. My buddies that were within earshot thought for sure I grenaded my fancy big block. (so did I...)
    I don't much care for flex fans....
  7. junk yard kid
    junk yard kid
    i dont like em ive seen holes in hoods and fenders from em, when i was younger i put two fan extensions together to get the fan closer to the radiator on my 66 chevy school bus, well after i got the exaust done i reveed the 454 in first and when i hit second the water pumps shaft broke destroying a radiator, both radiator hoses and dented a inner fender, your shoulda seen the fan though, after i picked up the fan i thought wow that was a stupid corner to cut, i built a bitchen fan shroud after a radiator recore.
    racer-x likes this.
  8. Anderson
    Anderson
    Flex fans suck. Period. Get a thicker steel fan...speedway has them, summit has them, etc. They will work better with a far less chance of killing you.
    At a Kwik Kar I worked at a few years ago (happened before I'd started working there) the manager and asst. manager were working on the managers mullet mobile after work one night. They'd just finished putting a big block in it with some redneck engineering. The asst. was checking the timing with a light under the hood, the other guy was in the car working the throttle.....flex fan came apart and went through the asst. managers chest and face.....he's one ugly sumbitch now.
  9. 1320Paul
    1320Paul
    Lose the flex fan. I spun my small block showing off for my friends like a dumbass about 15 years ago. KABOOOOOOOM!!!! Luckily the only damage was done to the frame. The frickin blade stuck in it like the sword in the stone......and I pooped a little. :D
  10. HAHAHAHAHA!!! I thought I was the only one that said that. Yhanx for the laugh.
    P.S. I hate flex fan too. I've had two come apart on me, the first one was pretty old and I should have shit canned it a month before it came apart. The second was like two months old and it let loose and punched a hoe in my hood. Get a clutch fan.
  11. budd
    budd
    i had one come off as well, it was on a pulling truck with a 400 sbc, brand new fan with a long spacer, looked to be running true as could be, decided to check the max. advance on the timing, my buddy held the throttle at 4500 while i put the timing light on it, closed the hood and my buddy gave it another shoot on the throttle, fan came off and chewed the crap out of the inner fender right where my face was 30 seconds before that.
  12. Mr48chev
    I've had the metal blade flex fans come apart as well as the glass ones. Not quite as exciting but they tend to loose blades after a while.
  13. The Shocker
    The Shocker
    As far as damage to the hood ,i would rather do that and contain the loose blade than hurt someone,but i doubt at 6500 rpm that the hood would stop much .
    I have also heard of the other types coming apart as well (glass and steel).I wander how many of these that came apart in the stories were already cracked before they flew apart?I inpect mine often for cracks,but i know it can prolycome apart without warning as well.I guess the only foolproof deal is to take it off completly and get an electric unit ,but i hate the way an electric looks on a hotrod (especially a gasser) ,and when your in Dallas traffic and the electric goes out you are screwed.Thanks for all the info and help guys .I think i am gunna try and make a real strong shroud and get a steel one...
  14. Anderson
    Anderson
  15. racer32
    racer32
    I'd second the suggestion to get a clutch-type fan. The clutch will only let the fan spin to a certain rpm and then it "slips" due to air drag on the blades. Less horsepower used to move excess air. I'd go electric for the track for that reason, but I'm not married to the idea of having everything be 100% era-correct on a car.
    zzford likes this.
  16. HOT40ROD
    HOT40ROD
    from Easton, Pa
    watch out for the ford fans. I know back in the 80's they had a recall on the fans because they were coming apart even at idle. There were some people hurt and even killed by them. Boy I just dated myself on that one.
    I have not ran a flex fan after that recall.
  17. Perry Hvegholm
    Perry Hvegholm
    Old ass thread, but still relevant. This statement is totally incorrect. The clutch in a factory type clutch fan is controlled by one thing and one thing only: thermonics (heat). It doesn't matter how fast you go. If your motor is hot and you have a clutch fan, the clutch fan is going to lock up and spin that fan no matter how many RPMs you're turning.
    Now, there are viscous speed coupler clutch type fans, but they are race only items, not factory...and these are useless on the highway. Try towing with one of these...or even just make a run up a steep grade. High RPM...load on the motor. Maybe you even have AC and you have that cranked too. No fan running because your viscous RPM race clutch has your fan disengaged...
    I've run a number of flex fans over the decades. I have never once had a flex fan come apart on me. I've never been sliced up by a flex fan as others claim they have. Use a large paddle blade model of quality design. If you use a cheap product, you can expect commensurate results.
    If you race, I would not use a flex fan. If you spend any time at all on cruise night and your car is a street car, paddle blade flex fans are a great option. They move prodigious volumes of air, especially when used in conjunction with a good shroud.
    I had a mechanical (solid steel) fan throw a blade on me more than once.
  18. Kiwi 4d
    Kiwi 4d
    Are we talking plastic Flexi fans or stainless steel ones that could explode?
  19. Beanscoot
    Beanscoot
    It's a good idea to not be in line with the fan when the engine is revved up and the hood open, especially when working on the car.
    zzford likes this.
  20. I only use steel bladed fans. HRP
    Spooky, Gman0046 and KoolKat-57 like this.
  21. gene-koning
    gene-koning
    I had an old Dodge 4x4 that I used as a tow vehicle. One day the motor developed a shake on start up, the morning after a late night haul. When I shut it off I noticed the fan had stopped where I could clearly see it was was a fresh break for a missing blade. The blade was no where to be found, apparently it came off during the haul the night before! It had to have vacated through the bottom as there was no dents in the hood, and I had no idea it had come off. When it broke off and came out, it missed everything! The entire rad shroud was undamaged, all the belts were accounted for, and the trans cooler lines were OK, nothing was damaged except the fan. I replaced that flex fan with a solid steel 7 blade fan. I haven't used a flex fan since. Gene
  22. I don't much care for flex fans, and I have one as a wall hanger where it can't hurt anyone or anything. :eek:
    Deuces likes this.
  23. Perry Hvegholm
    Perry Hvegholm
    It's the aluminum blade flex fans that fail (and have given flex fans a bad name)...and from a metallurgical standpoint, that makes perfect sense. Aluminum is not a metal that is known for its durability when it comes to it's elasticity. I have two cars that are equipped with quality large blade, stainless flex fans. One has been in operation thru two motors and 200,000 miles. This fan replaced a rigid steel fan and clutch that threw a blade long ago. Only reason the blade didn't pass completely thru the hood is because it hit an underhood cross member. Still dented the hood skin.
    Again...people shouldn't go cheap here. You get what you pay for. ​
  24. Perry Hvegholm
    Perry Hvegholm
    From what ive heard the early Flex a Lite flex fans had issues because of weak blade mounts. I cant speak from personal experience on these though. I use these and they're a solid product. I sometimes spend hours on the cruise at events like Hot August Nights. They keep even cammed up, ported engines cool at idle.
    https://shop.advanceautoparts.com/p/imperial-high-flow-flex-fan-221615/6014925-p
  25. Deuces
    Deuces
    Sorry fellas...... But I'd rather stick with a 7 blade clutch fan.... I've seen what the flex fans can do when they explode....
    Spooky likes this.
