Technical Flex plate balancing
Discussion in 'The Hokey Ass Message Board' started by Rustytoolss, Oct 14, 2025.
  1. Rustytoolss
    Rustytoolss
    Doing an engine swap. The engine is externaly balanced. The stock flex plate for the engine has balance weight on it. The trans flex plate and converter are an internaly balanced pair for the trans.
    Question. If I match up the loctaion excatly on the non balanced flex plate/ with the weighted flex plate. Can I just remove the weight and install it on the interaly balanced flex plate in the same location would that work ? Is it safe to do ??
  2. squirrel
    If you weld it good, it should be safe. Will the balance be perfect? probably not. Will it be good enough? maybe, maybe not.
    are you gonna tell us what kind of engine it is, or do we have to guess? :)
    jet996 likes this.
  3. Rustytoolss
    Rustytoolss
    Well this is on my 73 Javlin, which is externally balanced, The trans mission is a 87 jeep unit which is internally balanced. I know this is not the kid of thing for this forum. But as you can see I do have a vintage dodge truck. I thought if any group would know about this kind of thing H.A.M.B. guys would know.
  4. MAD MIKE
    MAD MIKE
    from 94577
    Would it just be easier to drill the holes for the TC in the flexplate rather than guestimating balance weight placement?
  5. squirrel
    Which transmission are you installing, and what did it have to start with? I think they used the (GM) TH400 then the(chrysler) 727 with those engines in Jeeps.
    saltflats likes this.
  6. rpm56
    rpm56
    Take the new and old flexplate to your favorite automotive machine shop for an easy balance.
    49Olds likes this.
  7. Mr48chev
    If the converter bolts to the externally balanced flexplate off the engine why would you not just use it. Seeing you say that it is "balanced to the transmission" sounds like you have been listening to a ******** artist extraordinaire as first, I have never heard of balancing a transmisison and every converter I have ever seen is balanced so it should have 0 vibration and be neutral in balance as far as the engine is concerned. You use the correct flexplate for the engine as long as the transmission bolts to it.
    MAD MIKE, 427 sleeper and seb fontana like this.
  8. Rustytoolss
    Rustytoolss
    overdrive
    I guess I should have worded that differently The 360 is externally balanced(damper& flex plate) . The transmission is from a jeep 4.0L (it's a AW4 overdrive trans) the jeep 4.0 is internally balanced. The swap says to use the 4.0 flex plate on the 360, and to rebalance the 4.0 flex plate to match the weight of the 360 flex plate.
  9. Rustytoolss
    Rustytoolss
    I just checked that out. I have to use the jeep 4.0 flex plate and starter to install the overdive trans..it was a good idea, but won"t work.
  10. MAD MIKE
    MAD MIKE
    from 94577
    Curious what the problem is.
    Looking up flexplate for an 87 4.0 Cherokee and an 87 5.9 Grand Cherokee.
    • Both are 13.83" diameter
    • Both are 164 tooth
    What is preventing the 360 flex plate from being used?
    Does it have some offset?
    Have you compared your '70 360 flex plate to an '87 5.9 flex plate?
    HemiDeuce and Budget36 like this.
