I'm building a blown big block for my C cab (Pie wagon) is this flexplate for a 454 ? It has a large counterweight.
Pretty sure it is from what I recall 40 plus years ago. But, building a blown 454 is an expensive undertaking. Why look at a used flexplate?
YUP ^^^^^^ They start at about $65.00 and go up to about $170.00. No reason to cheap out on the part that is likely to remove part of your foot.
Yeah, that looks like the right one...if you're running a 6 bolt TH400 converter, like they used in trucks. It's not drilled for the smaller converter bolt pattern that we usually use, as found on the TH350 and most aftermarket converters.
I had a squeak that some internet sleuthing suggested might be my flex plate (stock carbed 350 in my daily). I removed the flex plate and sure enough, it was cracked BUT, those cracks were EXTREMELY hard to see. Lucky me, I had a stash of used flex plates in the loft of the garage. I entered the loft, located the used flex plates and ... threw them all in the garbage (was at least 8 of them, I am NOT kidding). I then went and bought a new one, SFI rated and we all lived happily ever after As other have said, with the cost being so low for a new one, and especially with yours being behind a healthy engine, you can't afford not to buy a new one. Actually, now that I think about it, I believe a former neighbor took a few to use for some "steam punk" thing he was working on.
A average SFI flex plate in cheap Up grade , But it really depends on Your engine combo , Just because you add Blower/Supercharger does not mean you will exceed Oem strength, If you start to exceed 500 pds of torque on automatic More up grade I would be concerned of , Crack in flex usually thrust bearing problem , 35 years ago Just to see as experiments for myself and lasted two years street & strip . Blown with 10 psi on 9-5.1 I made little over 600 hp on stock block 400 sbc Cast crank , stock rod , stock balancer, stock Vega converter , 400 trains up graded clutches, stock u joints , stock drive shaft ,12 bolt, 3:55 gear ,radial 3,500 pds Et 6:50s @ 107 1/8 Took stock 454 added .530 cam hyd , 12 pds boost 1,500 pnd car 4:11 gear , pro stock tire ( size @ time 1998) Et 5:60s1/8 again just playing around
