Projects FLIPPING THE FRONT AXEL ON A 59 F100
Discussion in 'The Hokey Ass Message Board' started by ALLDONE, May 17, 2025.
  1. ALLDONE
    ALLDONE
    good pic...can see where the axel is welded on the pad...
    you could set the caster and then weld it
    Tim likes this.
  2. ALLDONE
    ALLDONE
    scrub line looks pretty low...and it looks like 3/8'' plate??
    GuyW likes this.
  3. ALLDONE
    ALLDONE
  4. ALLDONE
    ALLDONE
    the only thing I will do differant ... is add the pipe pieces ... looks like there would be a lot of stress on the axel where the nuts are, and the pipe pieces would allow more torge on the U bolts with out breaking the flange
  5. twenty8
    twenty8
    Well, thank you very much. I thought it would be a very helpful image when I posted it up for you. I am surprised you didn't take any notice of it the first time around........:confused:
    57 Fargo likes this.
  6. Tim
    Tim
    from KCMO
    Yeah kinda like a crush tube. That makes enough since to me.
  7. twenty8
    twenty8
    Weld the tubes top and bottom as well as welding the new bottom plate to the axle. Much stronger if the whole axle/pad ***embly is "one-peice".
    More importantly, DO NOT weld the new bottom plate at the ends. Only weld along the front and rear. Welding the ends across the axle could cause a possible stress fracture point on the axle....... Something you don't want.
    GuyW likes this.
  8. ALLDONE
    ALLDONE
    now the steering problem...
  9. ALLDONE
    ALLDONE
    yet another ill advised project,..took the truck to the shop,... here's the scope of work to be done.... took all the parts u bolts ,plates and such.... flip the axel... lol... they say WTF????,, just do it....I say...I get a call... "you need to come down here... we got the axel bolted in like you said, how you gonna steer it? every thing hits the springs now!" can we make it work???? " this is your mess and we don't have the time to do this hokey ****...you come say what to do and we will do it... the rest is on you... and don't ever say we had anything to do with it" I say, lots of people have done it with no problem,... " "maybe you should just take it to them"
    LOL... now what...Boys are pissed off that this fridge is sleeping on the rack.... it's a cheep shop/parts runner...now it's a parts truck that ran when parked.......
  10. Took it to the wrong shop
    there’s tie rod end drop blocks
    Dropped tie rod ends
    The ones I’ve seen flipped have the drag link running above the leaf spring. A proper reamer can be used to flip the tie rod ends if needed.
    Sometimes steering arm are heated and bent.
    Mine had the old style ball type rod ends so those were simply flipped for drag length clearance.
    the steering link geometry might have to addressed as well.
    there’s a bunch of info here
    https://www.jalopyjournal.com/forum...00-with-an-axle-flip-1961-1964-i-beam.531700/
    The pics **** due to photobucket issues though
    Okie Pete and ALLDONE like this.
  11. ALLDONE
    ALLDONE
    very good post, all noted and known...one other was to put hems, but they don't wanna do nothing till I say what to do....the real problem is they never would have done it this way to begin with,... the added problem is the power steering conversion that was all ready done hokey...so I have to go to the shop and say what I want done... the spring is in the stock location...the axel is on top... speedway has the dropped tie rod ends...2''... don't know if thats enough...they're way too busy with customers cars to fuc with my stuff, then add that it not right makes them pull away and go make money to keep the light on.....when a car goes on the rack it has to get done or get off the rack...my racks are like *****s *****'s... they have to go up and down to make money....
    these exist for ford drop axles and dropped twin I-beams.
    Never used em but they do exist.
    A proper degree reamer will allow the dang link to flip as well.
    Okie Pete, ALLDONE and patsurf like this.
  13. ALLDONE
    ALLDONE
    went and looked , here's the problem...the cross steer power steering... and the steering is hooked to the tie rod... if you go on top of the steering arm you have less than 1'' travel...to the frame and pan.... if you drop the tie rod... then the steering won't hook up and if it did death wobble and for sure bump steer... soooo. the steering has to be changed... and even then the whole thing would be still real hokey.... but this is the hokey *** board so I guess thats ok...
    but thats the reason my son said come look at it as I told him how fast and easy it would be... nothing is fast and easy that turns out right.... might work.... but....
  14. Pics of steering
    ALLDONE likes this.
  15. GuyW
    GuyW
    OK, put the axle back below the spring until you get it figured out. The welded plates won't hurt anything...
    ALLDONE likes this.
  16. ALLDONE
    ALLDONE
  17. ALLDONE
    ALLDONE
    they just u bolted the spring plates and axel to moc up what to do... so thats what I said before I left... maybe make it g***er style....lol
    GuyW likes this.
  18. ALLDONE
    ALLDONE
    oop's for got... nothing is welded
    GuyW likes this.
  19. ALLDONE
    ALLDONE
    the flip lowers it the thickness of the spring and the axel....... correct???
    Tim likes this.
  20. twenty8
    twenty8
    Correct, and don't forget to add the thickness of the added plate to the bottom of the axle.
    GuyW likes this.
  21. ALLDONE
    ALLDONE
    thinking about removing the very bottom, and the 3rd leaf from the top....????
  22. ALLDONE
    ALLDONE
    thanks again... this pic shows why it works and won't work on mine....One time in band camp.... a guy I camr across had the drop axel, hit a big pot hole and it snapped the axel , went into the ditch, and rolled 3 times landing against a big oak tree that saved him from yard darting off the clif...the drop axels that are that long have scared me ever since... this was at the time when most every one was stuck on the Camero sub swap... (which I never liked or thought was a good Idea) but at my shop we did one after another...hokey at best try..
    but back to the answer...this truck still has stock steering.... and you can see the work they did to make the steering arm not hit, but my truck has power cross steer...yeah, could do rhe drop axel and a bunch of lego blocks every where... ,.. but just to get a parts runner truck lower doesn't seem worth the trouble... and the end result is just tooo hokey for me... the crown vic sub looks too low when done...like 2 or 3'' off the ground to the rac and pinion... the mustang 2 is probley the way to go as you can move the cross member up and re fab the rest... but for now.... I'm putting it back to as built till I get a better plan....
  23. Pick of the steering setup?
  24. ALLDONE
    ALLDONE
    in this you can see the bottom of the steering box above the u bolts...
    also see the stock steering arm will hit the frame..
    you can also see where the u bolt nuts will hit the frame on g out..
    anthony myrick likes this.
  25. ALLDONE
    ALLDONE
    in this pic you can see the cross steer tie bar with the 2 mounts
    you can also see that if you mount it on top it will hit the frame
    and below it will hit the spring...
  26. ALLDONE
    ALLDONE
    and in this pic you can see the pitman arm right above the screw jack
    my boys don't have time to fuc around, so even though I took it to the wrong shop...at least they did what was told... " put the new springs in, with the axel on top...and call me when it's done so I can look at it" they do long travel off road trucks and lowered air bag stuff...ls swaps and such... got a list of good paying customers...so stuff like this is done because "I" said so...
    GuyW likes this.
  27. Mr48chev
    That is pushing scrub line to the limit.
    GuyW and ALLDONE like this.
  28. lodaddyo
    lodaddyo
    my 58 , i built around 2008. I flipped the front axle and moved the steering box up to keep the draglink the same angle. I did a post on it a long time ago. I guess its still out there
