Float measurement for a WCFB
Discussion in 'The Hokey Ass Message Board' started by VSO737, Jan 8, 2024.
  1. VSO737
    VSO737
    I have read that the WCFB float adjustment is 1/8" primary and also that the adjustment is 3/4" of an inch. I have a 1956 Carter WCFB which I believe is adjusted at the 3/4" measurement.
    WHICH ONE IS THE CORRECT MEASUREMENT??
    Thank you in advance,
    LG,
    Mike
  2. jimmy six
    jimmy six
    Possibly from 2 different places. Both my WCFB’s primaries are about 1/8” off the gasket when holding the air horn upside but are not listed for a Chrysler.
    The kits I’ve bought had where to measure them. I believe your 3/4” is float drop.
    My Motors Manual for 1956 Chrysler 2314S-SA and 2367S-SA is 1/8” ….the float drop is 5/8” on the primary and 11/16” on the secondary.
    If you have a 2444S or 2445S, which are listed for a 55-56 Chrysler they are slightly different
  3. VSO737
    VSO737
    Thanks for the quick reply. I finally identified my carburetor. It came off of a 1956 Packard. When I ***embled the float, the gap was way too wide. I set it at 1/8" like the rebuild kit instructions suggested. Then while researching my carburetor, I came across a writing where it suggested the float should be set at 3/4". I tend to agree with the 1/8" and the 3/4" sounds more like the float drop measurement.
    NOW, I will research for the exact recommendation for the 1956 Packard WCFB.
    LG,
    Mike
  4. jimmy six
    jimmy six
    My book said the Packard is the same as the Chrysler. 1/8” is the important one. I measure mine including the gasket. Good luck.
    Deuces likes this.
  5. carbking
    carbking
    Primary 1/8 (Carter tool T109-232)
    Secondary 3/16 (Carter tool T109-222)
    The Carter tools measure float level as well as side clearance.
    Jon
    jimmy six and Deuces like this.
  6. carbking
    carbking
