floating axle housing
Discussion in 'The Hokey Ass Message Board' started by cktasto, Aug 4, 2013.
  1. gimpyshotrods
    gimpyshotrods
    With the exception of double-pivot designs, where the brackets rotate around the axle housing, and on a pivot below (or a functionally similar design), all of these systems are a compromise, in one-way, or another. Perfect suspension is difficult, and expensive. Pretty good suspension, with acceptable, predictable and manageable down-sides, is a lot easier to achieve. Some impossibly fast cars have gone down the strip, and into the history books, with just this setup.
  2. cktasto
    cktasto
    frustrating:mad::confused:
    Still not working. I'll wait till my daughter comes home to figure this out for me
      269.9 KB
  3. 60 Belair
    60 Belair
    Thanks pila38 and porkn****** I was leaning toward what pila38 said,
    (Well, you wouldn't have to totally re-engineer the whole rear suspension if you stick with the leaves that are already in place. Sometimes its just a preference thing also.)
    Appreciate the answers without the drama. We all come here to learn. :eek:Andy
  4. 2racer
    2racer
    this has one
  5. cktasto
    cktasto
    hey gimpy,
    do you know what brand the mount in the second picture is? I'd like to take a closer look at them before I pull the trigger on any of them.
    After looking closer at the one in the third picture I'm having a hard time figuring out how they'd slide on the leaf spring. It looks like there's a hole in the plate that the u-bolts go through. And that hole looks like it's intended for the center pin of the leaf springs. if thats the case then i dont understand how the mount can slide forward or aft...does that make sense? I must not be looking at it right. does the center pin come out? I'll planning on calling ch***isworks tomorrow.
    Also, how did you attach the shocks?
    thanks!
  6. gimpyshotrods
    gimpyshotrods
    #2: https://ch***isengineering.com/shopDetails.asp?ProductId=1148
    #3: Not sure how they slide, either.
    As for shocks, for a street going vehicle. I like to mount them at a 15º with the tops closer together. It helps with body roll, on the street. A simple crossmember for the tops, fabbed, or off-t******lf brackets on the axle.
  7. cktasto
    cktasto
  8. Moon Rocket
    Moon Rocket
    from GA
    I don't think body roll will be an issue with a fixed ladder bar set-up.
  9. gimpyshotrods
    gimpyshotrods
    True, very true.
