floor board repair
Discussion in 'The Hokey Ass Message Board' started by chi-poo, Apr 28, 2006.
  1. how thick of metal has every one been useing to repair there floor boards?
  2. 5window
    5window
    Probably not much help to you,but in my Model A I'm running 3/4" marine grade plywood with the bottom sheatherd with abou 16 gauge sheet metal for extra protection. Course there's also not much floor in a Model A coupe.
  3. tinmann
    tinmann
    18 gauge cold rolled with a few stiffening beads rolled in is all you need.... and don't try to weld things solid, you'll only end up with doors that no longer fit. Tack welds (with good penetration) every 1/2 to 3/4 of an inch will be fine... seam sealer to follow, primer and paint.....viola
  4. pool
    pool
    I'm doing the floor in a 56 chevy g***er for a friend right now. I always have good luck with 18 gauge and a few beadrolls.
