Technical floor mounted brake booster access panel ideas
Discussion in 'Traditional Hot Rods' started by flyn schlosser, Nov 10, 2016.
  1. flyn schlosser
    flyn schlosser
    from Elko,NV
    Hello ,
    I'm Thinking of putting a access panel for my floor mounted brake booster .My car is a 28 coupe .It has a metal floor what do you guys recommend that will be functional and looks good any ideas is appreciated..Pictures are helpful also .
  2. The 39 guy
    The 39 guy
    Well depends....Depends on your tools and skill level. You can just cut piece of steel a little larger than the hole and screw it down or get a little fancier using a bead roller. My main consideration is to make the hole in the floor large enough for you to easily service the part. In a Model A that may be a difficult thing to do as there is usually not much floor space to work with.
    I have attached some pictures of two covers I made for my coupe. IMG_8292R.jpg
    Original hole is way too small for the new tank and it's removable parts.
    New tank
    Cut with saws all on the straight cut and dremel tool cut off wheel on the corners.
    I used a HF sheer to cut out the pieces and this bead roller to finish the edges and add a stiffening bead.
    From below
    Secured with self tapping screws.
    This is the master cylinder location. New Mustang type cylinder is much longer than the stock one.
    That red thing in the previous picture is a plastic jar cap used to mark the radius for the end cuts.
    The bead roller was used to make the flanges and center bead.
    Those tabs that were marked out in the first pictures were bent over to fill the void from the strengthening bead in the floor.
    Secured with self tapping sheet metal screws. I used rubber gasket material to make a gasket around the edges of both covers.
    These were really pretty simple to make and if you are not going to cover the floor with carpet would look ( I think) pretty much like a factory install. Hope this helps.
    Sam
    Rich B., tb33anda3rd, i.rant and 2 others like this.
  3. jeffd1988
    jeffd1988
    That is nice.
  4. DDDenny
    Here is the M/C access panel I put in my roadster, same idea would apply to a steel floor.
    If you are going to use a rubber mat (my plan), or carpet, a simple flap laying over the cover should keep the lift off piece in place, no need to hinge it or screw it down.
    Should stay (reasonably) dry unless you plan on running through high water.
    In my case, with a ******* roadster in Oregon, there will be bigger issues than a little water seepage in the floor.
    The 39 guy likes this.
  5. 01springer
    01springer
    How about a cover from a small breaker panel?
  6. How about the gas filler door from one of the new-fangled cars? You could remove the spring loaded cathch and replace with a magnetic type, or push-in click -out style.
  7. flyn schlosser
    flyn schlosser
    from Elko,NV
    Thank you all awesome ideas
  8. LBCD
    LBCD
    I fabbed these using 304 stainless for the gas tank but the floor is fairly flat.
    I dont have a pic of the brake booster door but I had a spare floor patch that I used to make a door frame and door...fits like a glove.
    Sent from my SCH-I535 using The H.A.M.B. mobile app
    The 39 guy and flyn schlosser like this.
  9. flyn schlosser
    flyn schlosser
    from Elko,NV
    Unfortunate do not have you skill level or tools.It looks awesome by the way
  10. flyn schlosser
    flyn schlosser
    from Elko,NV
  11. jailbar joe
    jailbar joe
    I have an underfloor booster in my project and made the filler reservoirs remote by mounting them in a toolbox and running hoses to the m/c.
    in your case you could mount them in the trunk and run the appropriate rubber hose to the m/c...pretty simple
  12. Ritzy1
    Ritzy1
  13. belair
    belair
    Since I am a talentless hack, I used a length of a glove compartment door hinge and a s**** piece of metal for the one I put in my Apache.
  14. IronTrap
    IronTrap
    I used the step dies on the bead roller and recessed the floor pan, left the recessed flange and put a flat panel in (with a bead in it) for the cover. You can see it in the floor pan video we put together (jump to 8:11) .
    Allows for a flush mount cover. I'm sure there are countless ways to do it, as long as it works!
  15. Rusty O'Toole
    Rusty O'Toole
    Lots of cars had under floor brake boosters before the mid fifties. None of them had any access from above. They could only be serviced or repaired from below. Since they almost never require any, access was not needed.
    You may be thinking of under floor master cylinders. They were also serviced from under the car, but had an access plate in the floor for checking and filling the brake fluid. Just a metal plate held down by 1 or 2 screws.
  16. warbird1
    warbird1
    The access panel for the master cyl. in my roadster... from a P-51.
    lbcd likes this.
  17. LBCD
    LBCD
    Here is the spare patch piece I had that I was talking about in my last post...formed a frame then welded the patch panel to the frame and mounted it with a piano hinge...no cost and turned out nice. [​IMG][​IMG]
    warbird1 likes this.
