Technical Flow testing air filters for Stromberg 97
Discussion in 'The Hokey Ass Message Board' started by Hemi Joel, Oct 7, 2022.
  1. Hemi Joel
    Hemi Joel
    from Minnesota
    The question came up on the internet, how much flow restriction is caused by the perforated mesh on the Nystrom Performance air filter. So we decided to do a test. I have the Flow-Quik equipment that I have been using for some port development, and have found it to be very sensitive. I figured it would be easy enough to slap a carb on it. We tested the Speedway frogs mouth scoops that I use on my 8 carb Hemi, both with and without the filter elements, as well as a louvered steel unit with a paper filter, and the cast aluminum Nystrom housing with a K&N element. We made a very short video of the test, you can see it here here:
    I hope you find it informative.
  2. hrm2k
    hrm2k
    Very cool . Im glad to see this.
    Hemi Joel likes this.
  3. When I ran the scoops backwards above 125 mph the gas would get ****ed out of the carbs and end up on the windshield.
  4. Bugguts
    Bugguts
    Neat test. Thanks for showing us.
    Hemi Joel and seb fontana like this.
  5. Hemi Joel
    Hemi Joel
    from Minnesota
    Brian, I heard of that issue before, and Don Garlits said that's why he has that flat sheet metal plate mounted above his carburetors on his 8 carb dragster. I run them backwards on my hot rod and so far I haven't had that issue at 135 mph. With the full, unvented visor on my coupe, that might be a high pressure area at speed.
    Toms Dogs, Jet96, Tim and 1 other person like this.
  6. vtx1800
    vtx1800
    Very nicely done!
  7. Super interesting! I really enjoy tests like this, you did a great job. I’ve seen guys put the small, 10” Cheap**** chrome air cleaners on 366, 427, and 429 truck engines in C-60’s, and F-750’s and sitting still, the engine will **** down on the lid enough to see with the naked eye. This was a idle to WOT throttle yank. Think about what happens under full load with the secondaries open! The frog mouth with the gauze filter was particularly telling.
  8. seb fontana
    seb fontana
    from ct
    My old friend built a 3/8x4 flathead for his roadster. I got the tri carbs all adjusted and linkage set, blipping throttle was rewarding so I went home. I get a call a little while later and he says engine won't rev up, but idles fine. I go back and he shows me what it does and then he pointed out the black stuff on his white garage doors from the tailpipes. I was a little miffed then noticed he had put the little air cleaners on. Took them off and back to rewarding throttle. I made him a tri power air cleaner like used on BBF and engine ran really strong. I always wondered about the little cleaners flowing enough and the ones he had must have been worse than the little Taiwan's tested!!
  9. Tim
    Tim
    from KCMO
    Awesome
  10. Budget36
    Budget36
    I need to learn emojis on my phone so I can give you several thumbs ups!
    seb fontana and Hemi Joel like this.
  11. NoelC
    NoelC
    Well done! I'm very impressed with your presentation and delivery of it.
    30cfm drop, I'm going to look at those breathers a bit differently, for sure.
    Toms Dogs and Hemi Joel like this.
  12. Harv
    Harv
    from Sydney
    This is pretty cool.
    If it’s not rude to ask, how much is the flow equipment worth please Joel?
    I’ve had a to-do list job for a while of flowing the aftermarket manifolds that were offered for the Holden grey motor. I bought Vizard’s porting book, and had been kicking around the idea of building a flow bench per his guide.
    That book is getting a little dated, and I wonder if a simple setup is now available without having to sell a kidney to afford it.
    Cheers,
    Harv
    seb fontana likes this.
  13. Hemi Joel
    Hemi Joel
    from Minnesota
    harv, i bought it used, i'm not sure what a new one costs. i paid about$700 for it, but i didn't question the price when he offered it to me because the guy is a genius and he had already let me pick his brain for 2 hours and bestowed priceless knowledge upon me.
    clem and Budget36 like this.
  14. Harv
    Harv
    from Sydney
    Thankyou.
    I had a similar experience yesterday with an older gentleman, who is rebuilding a 1950s McGee fuel injection pump for me. I learnt more in the 45 minutes of listening to him than what it will cost to fix the pump.
    Cheers,
    Harv
    rmcroadster, seb fontana and clem like this.
  15. acme30
    acme30
    from Australia
    Thanks for taking the time and effort to share your results. Those paper elements in the chrome top sure didn't work real well.
    I recall reading some time ago of a similar test done perhaps in American Rodder or Street Rodder magazine but seeing the you tube was the ducks nuts
    Budget36 likes this.
  16. X38
    X38
    Excellent!
    Maybe if you ran some tape around the base of the little chrome one it would seal (and plug more flow!)
  17. Just.dale
    Just.dale
    Cool!!! Thanks!!!
  18. wheeltramp brian
    wheeltramp brian
    Yup those small paper ones are junk at best.few of my customers have ran them on sixes and are amazed when I take em off and the car is night and day.ive replaced them with k&n or Speedway knockoff ones.
  19. Hemi Joel
    Hemi Joel
    from Minnesota
    That's a good idea. I actually thought of a whole bunch of good ideas after I already made the video. Haha. Isn't that the way it goes?
    X38 and Budget36 like this.
  20. hotrodA
    hotrodA
    Great job!
    Amazing that the Taiwan piece did as well as it did.
    Wonder if that style with a K&N filter would do even better?
    I ran that combo on my roadster and it did well, it seemed, but with no numbers to substantiate anything, it was a **** shoot.
    Thanks for the hard data!
  21. This may be unrelated but years ago there was a candy red 1965 Corvette street car (Toronto area) with a 6-71 blown SBC. I was a teen when I saw it and I couldn't believe how small the air cleaners on it were. In my mind they had to be a m***ive restriction. A quick google search found an article on the car ... David Cohen 1965 Corvette. Apparently he still had the car in 2013 and still had the tiny air cleaners too. I guess a lot depends on the cars use but they, to me, just looked "off/wrong". Nice car though :)
    https://www.motortrend.com/features/1965-chevy-corvette-stingray/
  22. seb fontana
    seb fontana
    from ct
    What about when they run a scoop with little cleaners stuck inside? Or them flat top injector scoops with the throttle plates?
  23. 1pickup
    1pickup
    Nice work! I was a little surprised at the paper filter in the little chrome bonnet. I expected worse numbers. It would have been interesting to use one of the old style bonnets w/ a screen instead of a paper element. I noticed a difference on my old dual carb straight 6 when the filters were installed, but it's probably not too smart to run open carbs for every day driving.
  24. Automotive Stud
    Automotive Stud
    I'd like to see the louvered air cleaner with a k&n filter also. It's probably worth noting that most of the original chrome air cleaners had wire mesh instead of paper elements, which I ***ume is also less restrictive.
  25. theHIGHLANDER
    theHIGHLANDER
    K&N are oil soaked gauze with "bigger holes" than paper elements. The improved performance they claim is hype. This has been proven over and over. Great testing Hemi, pretty revealing if you study the data a bit more. And in the grand scheme of things 13 CFM from the cheapy would never be felt short of a stock cl*** drag car looking to set a record. With forces being exponential in their natures I'd also bet the restriction in the cheapy was less, way less, at a lower demand like simple part throttle cruise mode. Data. It's a drug.
  26. Almostdone
    Almostdone
    Neat stuff. Thanks Joel.
    John
  27. Petejoe
    Petejoe
    from Zoar, Ohio
    I’ve found K&N’s have poor flow for my 94’s. I pulled them out immediately.
    Interesting study. Thanks for sharing.
  28. swade41
    swade41
    from Buffalo,NY
    Great little comparison,Engine Masters did a dyno shootout with aircleaners and there were some surprising results, the best was how much hp flipping the lid on a stock aircleaner ***embly, the K&N shown great results in it.
  29. @swade41 Did you post something? All I see is your avatar...
    swade41 likes this.
