Hot Rods Flush fitting A Model coupe doors
Discussion in 'The Hokey Ass Message Board' started by panhead_pete, Dec 22, 2019.
  1. panhead_pete
    panhead_pete
    Been trying to find threads where A Coupe builds have been altered with flush fitting doors like a 32 does without much luck. Has anyone done one? If so how please? I know the vicky doors do, just wondering how it could be done with a coupe :)
  2. Russ B
    Russ B
    I thought long and hard about doing it to my 29 coupe, but in the end I figured the amount of work would be way too much. Probably, it would be easier to give a deuce some Model A styling.
    Just Gary and alanp561 like this.
  3. oldiron 440
    oldiron 440
    That goes with the billit door handle crowd....
  4. lothiandon1940
    lothiandon1940
    Why take away all of the charm of a Model A?
  5. scrap metal 48
    scrap metal 48
    I agree 100% ^^^ with Don...
    lothiandon1940 likes this.
  6. I've done it on both a 31 coupe: moved the cowl forward, built a stepped rear and top door jam (hammerformed over a steel form I cut) and chopped the door a little more than the roof so the top of the door fit inside the opening.
    As well did it on a 29 sedan. All the same steps, but cut and moved the rear door jam and 1/4 panel back the required amount.
    Stopped a lot of wind noise and door creaks when done.
    panhead_pete likes this.
  7. Kan Kustom
    Kan Kustom
    Nothing tackier than doors flapping over the body. Even Henry didn't like it. He changed them gradually by flush fitting the front edge in the thirties A's and went all in on the 32. Hotrodders started flush fitting A's as soon as they had skills to do it, same as Henry . Same with exposed hinges. On this site many want to go all the way back to ancient times but there are just some things shouldn't be replicated in my opinion. I like a lot of what goes on here as things have gone too far with hotrods until they don't even resemble what they are but there are just many things that are just hokey and had no cl*** until someone improved them. To each his own. I flush fit all of mine. It takes a lot of skill, experience and patience to flush fit doors and you asking how to do it may indicate you should probably have someone do it for you that has been there and proved theirself if you don't want to chance mutilating a body. I am with you though that they need it and to those that say get a 32 don't get it that some of us like Model A's ,33,34,s etc. better.
  8. alchemy
    alchemy
    Yep, you need to improve those A's. They are the ugliest things around when they still have their overlapping doors, hinges, visors, door handles, fenders, headlight bars, bumpers, hoods and hooks, rubber on the running boards, and got forbid a windshield frame. Smooth them up just like a baby's ****. And paint them a nice baby blue or creamsickle while you are at it.
  9. Never2old
    Never2old
    from so cal
    Spend all the time you want but it’ll never be a Camaro.
    X38, deathrowdave, oldcootnco and 4 others like this.
  10. Chappy444
    Chappy444
    Anyone know what car (or builder) is considered the first Model A to have flush fit doors and/or what year it happened?
    I like mine how they are, I notice the overhang briefly just before I open the door and get in, then I start it up and forget all about the doors...however, I could see doing it just to get rid of the rattling...lol
    Chappy
  11. dana barlow
    dana barlow
    from Miami Fla.
  12. That is easy Ford built them in them in 30 and 31. All the Murray bodied car had flush closing doors. Briggs bodies had overlapping boors. Or should I say the Slant window series cars got flush closing doors.
    flatford39 likes this.
  13. lostone
    lostone
    from kansas
    On my 31 tudor I took and cut the upper and lower rails up against the rear quarter then moved the rear section back until I got a good 1/8" gap. Tacked a piece of 1/8" strap on the inside top rail, did the same to the lower. Latter I will cut a filler piece just to fill the upper and lower rails to hide the slice and dress.
    I moved the cowl/ header forward and left the upper panel above doors in its original portion to the rear body and i 'll build a small filler if needed to the front header.
    Yep over lapping doors is a great idea thats why we still have them today. To go along with mechanical brakes.....
  14. LAROKE
    LAROKE
    The problem I see is that everyone will tell you you're full of **** when you tell 'em afterwards at a show is that it is a Model A.
  15. A model A can be how ever you like it to be. They're no less a HOT ROD if you fill the roof, get rid of the drip rails ,and flush the doors. My 29 coupe has all of those done. I don't think it's any less of a HOT ROD than my 31 witch none of that has been done.
    Like said, It just takes a lot more time.My good friend, and metal man Moose helped me with it . A lot of work for sure! But it's how ever you like it the best. I'm Cool with them done both ways. The 31 started with a cherry body, but the 29 needed a lot of work anyway. Mine has been called a r. rods, street rods, and hot rods. But I just call'em FUN! lol
    Sent from my SM-G920P using The H.A.M.B. mobile app
  16. lothiandon1940
    lothiandon1940
    ..........................and thus, street rods were born.:rolleyes:
  17. Russ B
    Russ B
    My 1929 Ford Briggs Body cabriolet has flush fitting doors.
  18. 66gmc
    66gmc
    Now that is a bad*** coupe, flush doors and all!
  19. panhead_pete
    panhead_pete
    Ah some of you guys crack me up. I love A's (32s not so much and Ive owned a couple) but the over lapping doors always have looked 1/2 ***essed to me on an A, as patiently it did with Henry, hence the changes with the slant window cars. Silly me for wanting something slightly different...
    Now if only they had built a slant window coupe and I'd have all that I seek, but I digress.
    Appreciate all the helpful advice so far though, particularly from those that have done it.
    Kan Kustom and Stogy like this.
  20. Mike Colemire
    Mike Colemire
    I don't care if the doors hinge from the top on Ron's coupe, that is a bad a$$ car!
    Tim, panhead_pete and lothiandon1940 like this.
  21. gary kessler 1932
    gary kessler 1932
    Barry Lobeck, did the door thing, to his 29 sedan del, back in 74,
    Kan Kustom likes this.
  22. lothiandon1940
    lothiandon1940
    ...............It's all good. What kind of world would it be if the only ice cream flavor was vanilla?!
    Kan Kustom, panhead_pete and alanp561 like this.
  23. Model A Gomez
    Model A Gomez
    Takes a lot of work to flush fit the doors especially on 28-29 where the front overlaps too. A friend started to flush fit the doors on a 29 coupe years ago and finally gave up and bought another body, was above his skill level. After over 30 years of owning Model A's they have never bothered me but does clean up the lines.
    Kan Kustom and panhead_pete like this.
