Hot Rods Flush fitting doors in a Model A?
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Dec 12, 2020.
  1. flynbrian48
    flynbrian48
    I’m out in the shop waiting for filler to set up on the DeSoto, and easily distracted I began playing with the roadster.
    I never really cared for the overlapping doors a Model A, and as long as I have to cut these down an make inner panels, why not make them fit flush? Here’s one of the door skins cut to fit. I’ll have to take more off for a gap, but I think this looks nice.
    Good? Bad? Indifferent?
  2. pitman
    pitman
    Smooth, def. an improved version. Murray? Briggs? :cool:
  3. flynbrian48
    flynbrian48
    ‘Gl***.
    pitman likes this.
  4. goldmountain
    goldmountain
    I Don't think that will take anything away from its "genuine" status.
    Sent from my SM-T350 using The H.A.M.B. mobile app
    VANDENPLAS, mad mikey and irishsteve like this.
  5. flynbrian48
    flynbrian48
    The only Ford harmed during this build was whatever late 60’s lump the 8” came from. [emoji23]
  6. lostone
    lostone
    from kansas
    I flush fit the doors on my 31 tudor but I made the door opening bigger by cutting the lower rails and upper tie bars and just moving the cowl and doors forward 5/8".
    Hnstray, GordonC, gnichols and 3 others like this.
  7. pitman
    pitman
  8. flynbrian48
    flynbrian48
    If I make a wrong cut I’ll just glue it back together. [emoji41]
  9. Aaron D.
    Aaron D.
    I like it. Once you get done with the car and it's all painted up, looking down the side of the car is going to look nice and slick.
    bchctybob and pitman like this.
  10. lowrd
    lowrd
    Looks good from here, clean appearance.
  11. BamaMav
    BamaMav
    from Berry, AL
    Be careful, the street rod haters will be out with pitchforks!:D:D:D:D
    bchctybob likes this.
  12. flynbrian48
    flynbrian48
    I know, right? That “modern” engine and automatic transmission just ruin it! Most of the experts are here are building late 50’s four door sedans I think. [emoji41]
  13. mad mikey
    mad mikey
    Looks good and will be a more smooth clean look. Gl*** body, go for it.:)
    kidcampbell71 likes this.
  14. Roothawg
    Roothawg
    So where did you find a spot welder for fibergl***?
  15. 5window
    5window
    I like Model A's the way Henry built them. Your car, build it whatever way you want.
    Automotive Stud likes this.
  16. flynbrian48
    flynbrian48
    That's fine, but seriously, what are you doing on a traditional hot rod site?:p
  17. flynbrian48
    flynbrian48
    It's a skill I developed years ago. You just have to be careful not to try to run a bead or it gets real messy, real quick.
  18. Model A Gomez
    Model A Gomez
    Definitely cleans up the look, would be a lot of work on a steel car. I've done several Model A's and never liked the overlapped doors but to flush fit them would also requires modifying the cowl to let the hinge swing farther.
  19. 5window
    5window
  20. lostone
    lostone
    from kansas
    Mine, 31 tudor.
    Just finishing up on its 3" chop.
    mgtstumpy, ct1932ford and flynbrian48 like this.
  21. Bandit Billy
    Bandit Billy
    I like the smooth look on a roadster but I prefer the overlap on the coupes. I know, weird huh?
    flynbrian48 likes this.
  22. flynbrian48
    flynbrian48
    I get that you like them as Henry intended, my question is, this is a hot rod site. Where cars get cut up. In the style, usually, of the past. If I wanted a car as Henry built, I wouldn’t have a gl*** one, or have a Hemi in it. I guess I missed your point.
    Stan Back and kidcampbell71 like this.
  23. flynbrian48
    flynbrian48
    This I like! The fit is pretty good, I have to finish the framing and it’ll need a turn buckle to put a little more twist to keep the back lower corner in, but so far so good.
  24. tb33anda3rd
    tb33anda3rd
    I like the flush door edge, but it is only as "smooth" as the rest of the side of the car. on a 28-29 the cowl has the step and then, of course, there is the hinges. just my opinion/observation... carry on.
  25. flynbrian48
    flynbrian48
    Plus, the Hemi valve covers stick WAY out past the grill shell. [emoji6]
  26. bchctybob
    bchctybob
    It's a shame old Henry didn't make the doors flush, looks better and would have saved us all a lotta work.
  27. flynbrian48
    flynbrian48
    That's the fun thing about hot rodding. You are free to do what you want to whatever car you choose to build. Just be prepared to be told on the H.A.M.B. that you've done it wrong. :rolleyes:;)
  28. winduptoy
    winduptoy
    Henry did on a Vicky
    Yeah I know, someone won't like the step plate.... Oh, that was another thread IMG_20201213_181728166.jpeg IMG_20201213_181620787.jpeg IMG_20201213_181546965.jpeg
    Sent from my XT1585 using The H.A.M.B. mobile app
    D-Russ, mgtstumpy, bchctybob and 4 others like this.
  29. Street_Sinner13
    Street_Sinner13
  30. TERPU
    TERPU
    If you've ever spent hours fitting doors on a Model A then only to go over a driveway, a speedbump, or a bumpy and rolling road in a stock chasis model A you grow to appreciate them overhanging doors.
    You see them doors are what allows for that little tractor to articulate and flex like Ford intended and still have everything covered and "look" lined up still. Because sure as **** the first three hours of really driving your car screws up all that careful fitting for certain.
    62rebel, Tman, bchctybob and 5 others like this.
