Projects flush mount windscreen aka windshield !
Discussion in 'The Hokey Ass Message Board' started by buick bill, Mar 29, 2024.
  1. buick bill
    buick bill
    from yreka;ca
    im considering trying to mount the windshield in my latest acquisition .,41 chevy sd coupe/hardtop , using urethane .and a **** joint in the center .any advice /suggestions . from people with experience . ?should i use something to border the gl*** .? use the same thing for quarter /rear gl*** .any pix to share ? thnx .for all guidance IMG_3746001.jpg IMG_3755001.jpg IMG_3743001.jpg
  2. Unkl Ian
    Unkl Ian
    Guessing the front and side gl*** is flat. Not horribly difficult to make patterns.
    With a Vee **** in the center, the mating edges need to be ground and polished at the correct angle.
    Rear gl*** is going to be fun, if the opening is larger than the OEM gl***.
  3. dwollam
    dwollam
    Why not use stock type rubber gaskets?
    Dave
  4. buick bill
    buick bill
    from yreka;ca
    been there ... done that.... i lke a change ..gona do everything different on this one ! else why build another one ......... DSCF5604.JPG
  5. willys36
    willys36
    I did it on a '36 Pontiac project. Works fine. Articles on this project have been published over the years in rod magazines. You remember when there were rod magazines don't you? Just get the gl*** cut accurately so the joint just touches and is uniform with no gaps. On my project I got the rubber and made some 1/8" Masonite wood patterns for the gl*** shop. Probably best to do this even if you have the original gl*** for a pattern since a but joint will have slightly longer panes. I used clear silicone but that was before urethanes took over the market. Clear urethan rubber is by far the best option.
  6. buick bill
    buick bill
    from yreka;ca
    looks great .. thats what im looking for ..and the stock rubber is a pain in the .... to install . . no orig. gl*** .chopped 2 inch's , and b-pillar delete
  7. alchemy
    alchemy
    Back in the 80’s when the street rodders were smoothing everything out, they used to glue the gl*** flush and fill the gap with S-10 windshield rubber T trim.
    lowrd, alanp561 and anthony myrick like this.
  8. Yep. Street rod guys been doing it for decades
    lostone likes this.
  9. buick bill
    buick bill
    from yreka;ca
    thats it ...i wana be a street rod guy when i grow up ! been done , but never bye me .im needing the tee molding . or what ever is better .or comparable
  10. I’ve got a glued in on my bus. Used the WS primer on the gl*** and channel.
    Gl*** guy used a generic molding. Looks similar to a gasket.
  11. spanners
    spanners
    I looked into this a few years back when doing a '39 Chev. The gl*** people said no problem but their advice was not to use clear in the centre, use black instead or glue a fake moulding in. The reason was that it's like looking into a cracked mirror.
    My mate had a '37 Chev with clear in the centre and he backed up what the windscreen people said.
