Projects "Fly'nBrian" '34 Roadsterproject.
Discussion in 'Traditional Hot Rods' started by flynbrian48, Apr 28, 2016.
  1. flynbrian48
    flynbrian48
    It steers! The throttle works! I have brake lines and hoses! IMG_2273.JPG IMG_2275.JPG IMG_2277.JPG K
    oldsjoe, kidcampbell71, brEad and 6 others like this.
  2. flynbrian48
    flynbrian48
    Driveshaft: Done and installed. There's 2 fingers clearance at the back of the trans tunnel and floor under the seat. Good as it's gonna get. Front shock links: Done. Steering: Almost done. I discovered (or just noticed) that the hole for the drag link on the steering arm on the right side is tapered from top to bottom. Opposite of the tie rod. This means I have to ream the bottom half of the hole to put the tie rod in from bottom up. There's always something... 19748896_10214203359420572_7838407090087455145_n.jpg 19756527_10214203360260593_2731792130072327661_n.jpg
    kidcampbell71 and loudbang like this.
  3. Dean Lowe
    Dean Lowe
    Is that really how you want to run the double U joint in the steering?
    WiredSpider likes this.
  4. WiredSpider
    WiredSpider
    And did you weld on the steering shaft?
  5. flynbrian48
    flynbrian48
    The shaft is pinned and welded, and I guess I don't know how else to run the double U-joint. Too much angle?
  6. WiredSpider
    WiredSpider
    Too much angle.
    Can you put a u-joint where the weld is and eliminate the top u-joint and rod end?
  7. flynbrian48
    flynbrian48
    It's a shade less than 30 degrees, but I was concerned too. The column has a wobble joint inside the bottom end, I tried to keep it straight, and let the heim joint support the shaft, but I could I guess make the frame bracket a bit longer, swing the bottom of the column over a little and lose a bit of the angle. Nothing a cut off wheel and some more thought won't fix. Which is why I post photos, because somebody out there knows a lot more than I do...
    Special Ed and loudbang like this.
  8. WiredSpider
    WiredSpider
    Look a lot cleaner without the double u-joint and rod end,
  9. flynbrian48
    flynbrian48
    Hmmm. There is a U joint, or a flex coupler, in the base of the column, the shaft you can see (that I welded the double D shaft to, is only about 3" long below that), so that still leaves 3 U joints, and a need for the heim joint support.
  10. hotroddon
    hotroddon
    I may be wrong, but I believe those double joints are designed to operate where a single does not get enough angle - they are not designed for shaft misalignment to operate where each section works against each other.
    Also are those splined or just the one set screw?
    Dean Lowe likes this.
  11. flynbrian48
    flynbrian48
    Splined in the Vega box end, double D on the steering column end. I can move the bottom of the column toward the engine a bit and lose some of the angle.
  12. hotroddon
    hotroddon
    That's good - but I still don't think those joints are designed to work like that in rotation.
    I was always told they were for use like this - to get more angle than a single could provide
  13. You need Quik-Glo for those wheels order some up, will make that bad wheel look new
  14. coast40
    coast40
    The wobble joint on the column is not meant for a sharp angle. With that in mind, a possible solution would be to trim the column back, cut the wobble off, turn, pin and weld DD on for a 2 joint system. I really don't recommend welding on steering components, but it's better if you're certified. Or very good.
  15. flynbrian48
    flynbrian48
    That's why I kept the shaft straight, and used the heim joint. The issue is that I made the support bracket a bit to short, causing more mis-alignment than I, and all of you, like. Looking at it, and thinking about it overnight, it's no big deal at this point (and easy enough to do), to cut the bracket off, swing the bottom of the column over about 3/4", so as to line up the column and steering box a bit better, and make a new bracket for the support. There'll be less angle that the double joint will have to endure, and I won't get into the guts of the column and shifter.
  16. pigfluxer
    pigfluxer
    Looking good Brian, you are getting close.
  17. flynbrian48
    flynbrian48
    There. I fixed it. Thanks to the guys who said, "You aren't going to run that U-joint that way, are you?", I cut the bracket off the frame for the support joint, made a new one that put the support bearing 3/4" over to the right, and moved the whole column up 3/8". Now, it looks better, no binding, and I had to repaint that inside rail again anyway. ;-)
    Besty34, brEad, oldsjoe and 4 others like this.
  18. loudbang
    That was fast work :eek:
  19. flynbrian48
    flynbrian48
    LOL, it has to be fast, like "American Hot Rod" or "Gas Monkey Garage", I have an artificial deadline and I'm over budget! There has to be some drama! It only took an hour to do it right. ;-)
  20. oldsjoe
    oldsjoe
    Your on it Brian and it's getting there quickly! Joe
  21. coast40
    coast40
    I'll bet it works a lot smoother, too. Good job!
    loudbang and flynbrian48 like this.
  22. loudbang
    At least you don't have to worry about tripping over or combing your beard. :rolleyes:
    flynbrian48 likes this.
  23. flynbrian48
    flynbrian48
    I do use beard oil (smell'um) in my beard. ;-)
  24. hotroddon
    hotroddon
    Honestly that is not how I would have fixed that. I would have shortened the column portion of the shaft and put a standard U-joint there. The toss away the support bearing and the wobble joint and put a standard U-Joint at the box. You are still using that wobble in a way it isn't really designed for and over complicating it.
    Look at the bottom installation in this picture. It would make your installation cleaner, simpler and safer.
  25. flynbrian48
    flynbrian48
    The original shaft and whatever joint or coupling it has are now dead straight, as it was intended to be. It may be a vibration damper? Anyway, I'm happy with it as is, the angles now on the double joint are not extreme. Thanks for the input, I'm moving on to next thing I will do twice, brake and fuel lines.
    loudbang and oldsjoe like this.
  26. flynbrian48
    flynbrian48
    Or, by wobble joint are you referring to the double U joint at the box? I don't see why that won't work in this position?
  27. hotroddon
    hotroddon
    Will it work? It Might be OK, but it really isn't what they were intended to do in a steering application. Under load it might get a heavy or notchy feel as it tries to bind as it wants to flex in two different directions. You won't know until you put the dynamic load of actually driving it - turning it in your garage won't do the same thing.
    Like I say, it MAY be OK, personally I would just do it right, as the steering and U-Joint manufacturers recommend.
  28. flynbrian48
    flynbrian48
    is it the opposite angles of the joint on each side?
  29. flynbrian48
    flynbrian48
    Sigh... Doing three times now...
  30. Dean Lowe
    Dean Lowe
    It will be worth it in the end.
    Besty34, IowaMercMan, brEad and 2 others like this.
