Projects "Fly'nBrian" '34 Roadsterproject.
Discussion in 'Traditional Hot Rods' started by flynbrian48, Apr 28, 2016.
  1. Runnin shine
    Runnin shine
    Would phenolic 1" carb spacers give you the breather clearance and have an extra advantage of limiting some heat to the carbs? Might make more power too?
  2. flynbrian48
    flynbrian48
    Sneaky PCV It is then!
    brEad and loudbang like this.
  3. Dean Lowe
    Dean Lowe
    Been running only these Moon breathers for 15 years. No oil blows out (with 10lbs boost) and no moisture inside the engine. Just have to take the top off one of the breathers to pour oil in the engine.
  4. flynbrian48
    flynbrian48
    21034429_10214723713469098_5052830733065827408_n.jpg Brake lines are done! Well, I need to get under again and install some line clamps, but the hard part is done!
    kiwijeff, brEad, pigfluxer and 2 others like this.
  5. flynbrian48
    flynbrian48
    20993855_10214741455672642_7187182181855107839_n.jpg 21032553_10214741456112653_6468956613347857561_n.jpg 21077515_10214741456792670_7259237883893543992_n.jpg So, this happened. And brake lines done. And, fuel lines done. Yeah, I got this. ;-)
    koolkemp, OahuEli, kiwijeff and 5 others like this.
  6. Bandit Billy
    Bandit Billy
    Hell yeah my 34 roadster brother. All I need is a video of the first drive. Just around the corner. Build on!
  7. flynbrian48
    flynbrian48
    Whoops. Sometimes I get so caught up in what I'm doing I don't see what I'm doing. Notice the fuel line going in the "Out" port? And turns out the lower hose outlet didn't clear that flattened crossmember after all, once the Walker radiator was adjusted properly. It's all about the do- over ... IMG_2781.JPG IMG_2782.JPG
  8. Johnboy34
    Johnboy34
    from Seattle,Wa
    Have you thought about removing the breathers and welding up the holes?
    loudbang and hotroddon like this.
  9. flynbrian48
    flynbrian48
    I'm thinking about JB Welding the holes full and leaving the breathers on.
    porkshop and loudbang like this.
  10. Johnboy34
    Johnboy34
    from Seattle,Wa
    No offense but, is that a joke? Maybe for a conversation piece? I don't have a means to weld aluminum but I would take them to a welding shop and have them welded up. After sanding and polish they would be gone. Then add a small place on the top for your pcv, you already have the front breather so it would be all set. I've never used jb glue for anything before, and that is going to be in hot oil all the time so IMO it sounds iffy.
  11. flynbrian48
    flynbrian48
    Some of you guys take two 7/32 holes WAY to seriously.
  12. Johnboy34
    Johnboy34
    from Seattle,Wa
    If they were put on correctly, It's the big hole in the middle I would be concerned with.
  13. flynbrian48
    flynbrian48
    The valve covers have two 7/32" holes behind each breather. It matters not what size openings the breathers have, I could fill the little holes with gasket material and put a plate over them too, anything to block them off. It's no big deal.
    loudbang and porkshop like this.
  14. flynbrian48
    flynbrian48
    IMG_2789.JPG IMG_2791.JPG IMG_2795.JPG IMG_2796.JPG This is as good as I can make this hood and grill fit. Not perfect, but not bad for a bunch of aftermarket parts and a rank amateur trying to fit it all together.
    OahuEli, kiwijeff, brEad and 6 others like this.
  15. oldsjoe
    oldsjoe
    Most times trying to fit new and old together is just a PITA. Joe
    Sent from my SM-G900V using The H.A.M.B. mobile app
  16. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    I would be happy with that You can come fit mine anytime. Lookin guuuud bro er I mean Mr Brian
  17. flynbrian48
    flynbrian48
    Looks good from here, and I didn't have to fit fenders. ;-)
    loudbang, oldsjoe and Bandit Billy like this.
  18. Bandit Billy
    Bandit Billy
    I've been fitting mine for what seems like months now and I'd take that gap. ****, I don't even have hood sides.
    33 and 34 Ford's look great but nobody appreciates the fit and finish more than another builder of the same.
    Keep it up Brian!
  19. flynbrian48
    flynbrian48
  20. I'm diggin it..Cool!
  21. Bandit Billy
    Bandit Billy
    Brian, one thing that amazes me in building my own car is the longer I have it I keep changing things...and I haven't even got to drive it yet! One thing I changed was the 34 Tanks Inc unit like yours for a 32 tank that I modified heavily to fit my car. One item I milled for that 34 tank is an aluminum bolt on adapter and I fitted it for a flip top gas cap. Screws are countersunk, the cap base attaches with countersunk screws as well prior to adding the spring lid so they are also hidden. This wasn't a close up so it is not sharp but you get the idea.
    "spread 'em"...that there's funny.
    oldsjoe, loudbang and flynbrian48 like this.
  22. flynbrian48
    flynbrian48
    Billy, the one thing I dislike about the tank I have is the cheesy filler and cap. The cap has a machined finish (although it does have kind of neat knurled sides), which I thought about sanding and buffing off, then stamp "FUEL" on. My buddy "Crafty B" makes neat gas caps, but I may be out of money soon. ;-)
    oldsjoe and loudbang like this.
  23. Bandit Billy
    Bandit Billy
    One idea I had before I made that flip cap was to speed wire the fasteners on the tank filler neck. That would look pretty cool. The cap is cool that comes with it, if you mess yours up I'll send you mine. If you make it real cool, put a chain on it so a crack head doesn't walk off with it.
    Regarding Crafty B, I concur completely and already have some of his product on my car!
    brEad, flynbrian48 and loudbang like this.
  24. flynbrian48
    flynbrian48
    Today's project: new seat rise, a hump in the trunk floor for the differential, and replace the missing corners on the splash aprons. IMG_2811.JPG IMG_2813.JPG IMG_2814.JPG View attachment 3640537
  25. flynbrian48
    flynbrian48
    loudbang and brEad like this.
  26. Bandit Billy
    Bandit Billy
    ^^^Your work bench has salt flat rims, very cool. :cool:
    OahuEli, loudbang, brEad and 2 others like this.
  27. greaser
    greaser
    Picture may be deceiving, but how much fuel will you be able to put in the tank with the filler in that position?
  28. flynbrian48
    flynbrian48
    And my storage rack is a bagged, LS motivated '63 Riviera. ;-)
    OahuEli, oldsjoe, loudbang and 2 others like this.
  29. flynbrian48
    flynbrian48
    Uhh, I dunno. It's a stock '34 tank and filler, so prolly whatever amount fits.
    greaser, loudbang and Bandit Billy like this.
  30. flynbrian48
    flynbrian48
    Big step forward, all the plumbing is done! I'd been overthinking the upper radiator hose, and simply bought a preformed one, cut it apart and spliced it together. The trans cooler lines are done, likewise fuel and brake lines. Now prep for paint and get some color on this bad boy! IMG_2826.JPG IMG_2828.JPG IMG_2831.JPG
    kiwijeff, brEad, OahuEli and 4 others like this.
