Hot Rods Flywheel Question - Which one to use
Discussion in 'The Hokey Ass Message Board' started by Old 46’er, Jul 24, 2026.
  1. Old 46’er
    Old 46’er
    Hi,
    Some may be aware that I am currently working on ***embling an 8ba to put into my 46 SD Coupe. I am very appreciative of all of the ***istance I have received so far. I am looking for insight in to the flywheel situation. I have obtained the necessary bell housing and starter plate, but I'm not certain about what flywheel to use. Will the flywheel from my 59AB work on the 8ba to mate with my original manual trans?
    Thanks in advance!!
  2. leon bee
    leon bee
    Not easily I don't think.
  3. 51504bat
    51504bat
    Flywheel for a 59AB and an 8ba don't interchange. So the answer to your question is no.
    LOU WELLS and RMR&C like this.
  4. chicken
    chicken
    from Kansas
    You'll need an 8BA flywheel. The offset is different and the early wheel will likely rub on the back of the newer block as well as the starter to ring gear spacing being different.
    LOU WELLS, warbird1 and Algoma56 like this.
  5. chicken
    chicken
    from Kansas
  6. MARKDTN
    MARKDTN
    Yep, 8BA pressure plate bolt holes are drilled through. Earlier are blind. They will bolt up, but they won't work. Found out myself the hard way.
  7. leon bee
    leon bee
    And easiest is to find one drilled for the clutch you're gonna use.
  8. Old 46’er
    Old 46’er
    Regarding the clutch, I ***ume that I cannot use the clutch and pressure plate that was originally installed on the 59AB on the 8BA flywheel? Also, since I am a TOTAL novice with this, what sort of spacers or other parts will I need when attaching the flywheel to the motor?
  9. Old 46’er
    Old 46’er
    and another question, will my 1946 starter work with the 8ba flywheel?
  10. 51504bat
    51504bat
    Yes
    Old 46’er likes this.
  11. Old 46’er
    Old 46’er
    After removal of the motor, I read the part number stamped on my clutch. 29A-7550. Interweb tells me that it is a 10" clutch disc. Several questions:
    1. Should I ***ume that an 8ba flywheel drilled for a 10" clutch will work with this and the pressure plate, etc?
    2. I am having some trouble removing the lower bellhousing on my 59ab. Any pointers as to how best to make this work?
    Thanks, as always.
  12. alchemy
    alchemy
    A 10” flathead clutch should bolt up to all flathead flywheels with a 10” bolt pattern. Except the 8CM flywheel which probably has the diaphragm clutch pattern.
    The bottom part of a 59A bellhousing is welded to the oil pan. It should be very hard to remove separately.
  13. Old 46’er
    Old 46’er
    Ha! Thanks for that. I took off the clutch and the pressure plate. I’m hoping that these can be reused on the 8BA flywheel.
  14. alchemy
    alchemy
    The pressure plate has heat marks. Not really bad, but they are there. If you are in a big metro, you might have a clutch rebuilding shop that can surface it.
  15. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Actually, it was a Borg and Beck style pressure plate on the Mercury.
    alchemy likes this.
