flywheel question
Discussion in 'The Hokey Ass Message Board' started by onlychevrolets, Sep 17, 2009.
  1. onlychevrolets
    onlychevrolets
    Are 216 and 235 flywheels interchangable? I have a 216 straight shift and need to convert a 235 into one
  2. onlychevrolets
    onlychevrolets
    no body? not one of you guys know the answer to this question?.. OK what color should I paint my fat *** next door neighbor?
  3. squirrel
    12v flywheels are different than 6v flywheels. The starters use different gears, the flywheel teeth are different pitch and diameter. So pretty much anything from before 55 is different from anything 55 and later. Mostly 216 are before, mostly 235 are after.
  4. TagMan
    TagMan
    Will a 235 flywheel bolt onto a 216 and vice versa? Yes, but you'll probably have to use the matching starter motor, especially if using a flywheel from a 12v car.
  5. 6inarow
    6inarow
    You wait 34 minutes for a response and then post up this ****? Geez, patience dude...........
  6. onlychevrolets
    onlychevrolets
    thank you for your answer....
  7. OldBuzzard
    OldBuzzard
    I think (would have to go check the pile) some 216 flywheels are 4 bolt, 235's 6 bolt.
  8. Phil1934
    Phil1934
  9. onlychevrolets
    onlychevrolets
    must be a Georgia thing..I was thinking blue too
  10. ratrod0
    ratrod0
  11. BullyDog
    BullyDog
    from Atlanta GA
    I say black too..
  12. 6inarow
    6inarow
    No problem, just trying to help.
    But I think it was a stupid question. I did a search for "216 flywheel" and 3 pages of threads popped up, any number of which will answer your question.
    Like I said earlier, patience dude - get off your *** and look
  13. onlychevrolets
    onlychevrolets
    but I'm lazy like most people.....and the question wasn't stupid ...*****
  14. 6inarow
    6inarow
    you want me to come over and show you where to put the gas in it too????
  15. BullyDog
    BullyDog
    from Atlanta GA
    6inarow...whats your problem? The man's question wasn't a stupid one. the ***** may be a little much, jerk ,fits you better.
  16. 6inarow
    6inarow
    Its not a problem. I just said with a little patience and if the man did a search he would have found several PAGES of threads that answered is question. I'm sure if he searched "235 flywheels" several more pages would have come up. and his first comment is 30 minutes after he first posts up?
    All I was saying is that the question was already answered dozens of times noob, and if that makes me a jerk for pointing it out, so be it - I wouldn't run my mouth about being a jerk. I saw the "paint it black comment" before you edited it......
  17. The search engine here is like going into the Library of Congress, tons of information for sure. In fact, I rarely post questions on here because of all the previous discussion, I am so happy to have the HAMB Library at my finger tips!..........
  18. Funny ****, you dont get an answer in half an hour, and you *****, then you get pi55y because because you got called out on a question you could of asked jeeves
    for the answer, much less used the local search function, please....
    To make it worse, the questions ****s, it doesnt even tell what your trying to do, other then change the flywheel. Its a yes or no question, and a yes or a no wont tell you ****. If you dont have the patience to write a well thought out question, why should i take the time to answer it?
  19. slick39
    slick39
    from dallas ,ga
    LATEST NEW'S .....A world wind of **** hit's the the fan over a flywheel question....Damn i thought car guy's help each other out and i thought this also was a info site to
  20. 6inarow
    6inarow
    I think Onlychevrolets and I got it figured out in the PM's
