Technical Flywheel restoration? Who does it?
Discussion in 'Traditional Hot Rods' started by Mattbee, Aug 9, 2020.
  1. Mattbee
    Mattbee
    I picked up this old Scheifer flywheel for my flathead build but the steel insert isn’t rating away and needs replaced. Are there any shops out there that can remove the old insert and bond a new one to it? Thanks for the help.
  2. ekimneirbo
    ekimneirbo
    Yes! Ky Clutch 250 Gun Club Road Brooks Ky 40109 502 955 9173 Good people/Good prices They helped me so many times we became good friends.
    kidcampbell71 and Desoto291Hemi like this.
  3. dirty old man
    dirty old man
    If that flywheel is like the Scheifer for sbc I had in mid 60s, that's a bronze alloy metal spray. If moisture ever got in to the aluminum behind the sprayed area through heat checks, etc. then corrosion set in on the aluminum and got between the bronze and aluminum with the result you see here.
    I'm not sure they are still around, but one of the other custom flywheel makers may be able to machine it out and install a riveted in steel insert.
    kidcampbell71 and jimmy six like this.
  4. Rod&relics
    Rod&relics
    One of my old Weber. Flywheels looks rough also, thought it just a wall hanger, now maybe I should look into that. Price of new kinda far out there.
    dirty old man and kidcampbell71 like this.
  5. Fordors
    Fordors
    You might look into plasma spraying to get it resurfaced. The ‘wheel can be chucked up in a lathe and the damaged bronze can be removed. It can then be resprayed with about .030 bronze and resurfaced.
