...FNG 'outed' by Seymour.....
Discussion in 'The Hokey Ass Message Board' started by bgbdlinc, Jan 6, 2007.
  1. bgbdlinc
    bgbdlinc
    ...on another thread, I posted this pic......
    ....which got Seymours attention and he asked the following.....
    what year is the motor?....
    where did the adaptors come from to mate the Olds intake to the motor?...
    whay is the Lincoln valve cover doing there?...
    Answers:
    motor is a 368 cu in '56 Lincoln;
    I looked forever to find a multi-carb Lincoln intake (I know, I know) gave up and took a flyer on a simple rumour -that early Olds intakes almost matched the ports and bolt holes for the '56 368 motor. I got the intake on eGay
    found a bunch of Holley 94's (7RT's) and realized that although the siamesed ports lined up ok, the intake and the heads had different 'mounting angles' (for want of a better term) and the carbs kind of leaned inward towards the centre oil galleys. I went to my local metal merchant and bought two slugs of billet, measured, measured, measured, and had a machine shop plane one side down to make a wedge as a kind of ad hoc adaptor.....I then hacked out holes for the ports......
    ....the result is the first pic above (mockup) ....still have issues with water neck pipe but what the Hell...I'll figure something out.....
    anyway the rest of the car looks like this......
    ...and is a '46 Lincoln Club Coupe (pppullleese don't call it a 'Zephyr') with a full frame transplant from a '56 Lincoln.......hence the 368.....
    ....any more questions Seymour?
    bgbdlinc
  2. Well lookee there, some real hot rodding! Nice job.
  3. 53chieftian
    53chieftian
    Me likey the ingenuity there!
  4. Automotive Stud
    Automotive Stud
    Sweet!
    Seriously, it's not a Zephyr? Teach us.
    The motor is perfect in there!
  5. junkcad
    junkcad
    from nashville
    damn ! thats a bad *** car ! i need more pics please......
  6. bgbdlinc
    bgbdlinc
    ...Lincoln stopped using the 'Zephyr' name in 1942, I believe.....here are some more pics.....
    ...mockup with '48 Cad grille......shooting for the early Bertolucci custom essence......
    bgbdlinc
  7. Jalopy Jim
    Jalopy Jim
    That is great hot rodding at it best.
  8. draggin ass
    draggin ass
    from hell
    i got an olds intake on my caddy 331 too. just had to change the bolt holes.
  9. JohnnyP.
    JohnnyP.
    looking good.
  10. bgbdlinc
    bgbdlinc
    ...I'm ***uming the ports were siamesed on the Cad motor as well? Did you have the low or high rise Olds intake? Curious?
    bgbdlinc
  11. Royalshifter
    Royalshifter
    Moderator
    Seymour is a Ruler!!!! That car is sweet.
  12. Durod
    Durod
    from DFW, Tx
  13. What Kiwi Kev said, good work.
  14. ChuckleHead_Al
    ChuckleHead_Al
    Awesome man, and great looking ride...
  15. Automotive Stud
    Automotive Stud
    I felt my pants get tight when I saw that caddy grille!
    I don't know about that sunken tag though...
  16. graverobber63
    graverobber63
    Alliance Vendor
    sssshhhhhhhhhhhaaaaaaaaaa-weeeeeeeeeeeeet
  17. Take a look at your third picture. Are you planning on putting some kind of a divider in between the ports? It will run like **** if you don't. Just my $.02
  18. Destralo Roach
    Destralo Roach
    Hot Rod? That's one cool Kustom!!!!!!!!!
  19. Fe26
    Fe26
    nice work, commonsense with gusto!
  20. bgbdlinc
    bgbdlinc
    ....I can't take credit for the current state of the body work (i.e. sunken tag, funny tailights) since it was done by the disillusioned previous owner, however, a gang of guys and I got together last summer for the chop (The Great Canadian Back Bacon Whack!). Re: the sunken tag -I've seen early customs with them covered with transparent plexiglas -still undecided whether to fill it in or use plexi....
    ....the frame swap worked out really well since no lengthening or shortening of the ch***is was required and I really lucked out. The difference in the wheelbase between the the '46 ch***is and the '56 ch***is was merely 1" and the track was about the same -neither is noticeable.....
    bgbdlinc
  21. erock805
    erock805
  22. bgbdlinc
    bgbdlinc
    ...wasn't planning it put a divider between them -wouldn't the air flow just get a little more turbulence as it p***es from the intake to the heads? School
    me...
    Thanks
    bgbdlinc
  23. SlickT
    SlickT
    from Tn
  24. loogy
    loogy
    Knee toe!!!!!!
  25. seymour
    seymour
    from PNW
    haha... that's funny, bc I had a feeling it wasn't a later Olds, judging by the timing cover, shape of the valley cover, (lack of) freeze plugs in the heads, dip stick location and the 2 studs off the head... etc etc
    That's really cool!!! But one thing, isn't that a '49 grille?
  26. seymour
    seymour
    from PNW
    Yes, the best TOOL! :D
  27. Jerry_Rolls&Pleats
    Jerry_Rolls&Pleats
    from Europe
    That's gonna be one nice kustom! :eek:
  28. theHIGHLANDER
    theHIGHLANDER
    I think it will "blubber" at part throttle. The manifold will not function as designed. Also based on the firing order it may build up some serious reversion in one or 2 pairs of ports. You may also experience some vapor separation at higher speeds and wonder why a good mixture setting can't be found. Outstanding work, really. Only missing that detail. You'll be glad you did it.
    As far as the car itself, I don't know what the hell posessed you to do that to it, really. But what ever it was, keep it:D
  29. glenn33
    glenn33
    from Browns, IL
    Great Kustom...looks like you guys up north know what you're doing...keep us posted.
  30. BinderRod
    BinderRod
    Just goes to show you that just because you have FNG by your name does not mean that you don't know **** about cars.
    I'm looking forward to more pictures
    Great Job!!
